GRA Functions: Differences Explained
hno2fe
Post21-04-2003, 23:46    Subject: GRA Functions: Differences Explained Quote
Hello everyone,
I retrofitted a Gasoline Particulate Filter (GPF) to my Golf 4 Cabrio TDI with the engine code ALE.
Everything is working perfectly, but the engine control unit (MSA15.5) has different GRA functions.
1. Version (Standard GRA):
SET button for setting / accelerating.
RES button for speed resume.
'Press the AUS (OFF) key to turn off the GRA.'
With this version, no delays will be tolerated!
2. Version ( A simulation, GRA with delay ):
SET button to set / delay.
RES button for speed resume / Accelerate
PRESS the AUS (OFF) key to turn off the GRA.
What logging method can be used to switch between GRA versions?
Is that even possible?
Thanks & Regards, Olli
Translated on 28-08-2026, 7:35.
Post22-04-2003, 7:01    Subject: GRA Functions: Differences Explained Quote
The version of your GRA (Gas Recirculation) is determined by the software in the engine control unit (ECU), and therefore, it cannot be switched.
Given that the convertible largely consists of G3 components and was later retrofitted with G4 technology, I can definitely imagine that there might be different software versions used in it.
My G3 had version 1, and my G4 now has version 2.
I'm still pressing the SET button today to accelerate, and then I wonder why it's getting slower icon_biggrin.gif.
Translated on 28-08-2026, 7:38.
No new posts Funktionen der LED´s im B1 Diagnosegerät On-Board Diagnostics (OBD)
No new posts ECU Problems: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Klimatronik zus. Funktionen beim A6? Diesel Engine Technology
No new posts Beinhaltet das VAG-Com die Funktionen vom VAG 1551? On-Board Diagnostics (OBD)
