Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
13-05-2009, 10:23 Subject: Passat 3B6 AVF: What Battery Type? |
Hello everyone,
I currently don't have access to the database, but my colleague urgently needs information about the battery specifications (capacity, DIN designation) for a Passat 3B6 with engine AVF 96 kW from March 2001, which is equipped with Climatronic. It does not have a supplemental heater.
Can someone help me with this question? Gruß
Translated on 19-09-2026, 3:03.
Profile PM Garage |
13-05-2009, 10:36 Subject: Passat 3B6 AVF: What Battery Type? |
It can only be done through the promo codes.
J1L 60 Ah
J0L 72 Ah
(J0R 80 Ah)
J1R 82 Ah
I would guess it's 72 Ah. Transparency, Teamwork
Translated on 19-09-2026, 3:04.
Profile PM Garage |
13-05-2009, 11:37 Subject: Passat 3B6 AVF: What Battery Type? |
Thank you  .
//EDIT: It's a J0R, so an 80 Ah battery... Gruß
Translated on 19-09-2026, 3:05.
Profile PM Garage |
davidshoes Blaumann
Joined: 06/10/2002 Posts: 155 Karma: +6 / -2 Location: Sachsen
13-05-2009, 13:02 Subject: Passat 3B6 AVF: What Battery Type? |
I recommend a MOLL battery.
It's an OEM supplier, and if you can do without the VW logo, you can save quite a bit of money.
The dealer wanted around €190 for the A4 1.9TDI part, but I ended up buying the MOLL part for €135 including shipping.
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
16-05-2009, 20:33 Subject: Passat 3B6 AVF: What Battery Type? |
DIN 58043, also DIN 5 80 043, is the designation used in the open market. It is 313 mm long and 175 mm high. This is the ideal battery for Passat B5 and B6 diesel models, as it cannot be longer. It's the largest size that fits. And it's often the original equipment (OE) battery that was installed.
Varta now also offers a Silver Dynamic battery with those dimensions, which provides 85 Ah of capacity. Passat Variant BGW 2005
Translated on 19-09-2026, 3:06.
16-05-2009, 23:04 Subject: Passat 3B6 AVF: What Battery Type? |
"Everything is already in the paint. The guy got himself an 80s [model], and it's been in there since Thursday."
Thanks again to everyone for the help! Gruß
Translated on 19-09-2026, 3:07.
Profile PM Garage |
