ASZ Connector Pinout: Generator DFM Signal
oberministrant
Post29-05-2009, 15:19    Subject: ASZ Connector Pinout: Generator DFM Signal Quote
Hello everyone,
I am currently working on resolving the issue "ESP fails after 10 minutes due to an implausible generator load signal" (in ESP 18265 - Load Signal: Error Message from ECU, in ASZ 17911 - Load Signal from Alternator Terminal. DF: Implausible Signal).
I obtained the wiring diagrams from erwin, and I've already checked the connection L (blue wire) all the way to the body control module (connector XS4, pin 9) and found it to be in good condition.
After the intermediate connector on the transmission, the DFM disappears into a mysterious box 27, which is never mentioned again in a meaningful way (The number 27 sometimes appears with a different cable color on the climate control system, but you're less likely to encounter it there).
I actually assume that the DFM (Direct Fuel Injector) is directly connected to the engine control unit, and I've already measured all the contacts -> none of them have continuity.
Since I'm not entirely confident in relying solely on the cable color when replacing the wire, it would be great if someone who has access to better wiring diagrams could kindly identify the corresponding pin for me.
According to Jose from Seat, this data (signal description) is only missing from the VAS tester, even though some signal groups (SGs) have the data included in the existing plans.
Thank you very much, and best regards.
Markus.
Translated on 23-10-2026, 15:23.
Post29-05-2009, 18:13    Subject: ASZ Connector Pinout: Generator DFM Signal Quote
Disclaimer: As far as I know, pin 38 of connector 121 on the EDC15 is the generator load input.
Translated on 23-10-2026, 15:25.
oberministrant
Post13-06-2009, 15:15    Subject: ASZ Connector Pinout: Generator DFM Signal Quote
Thanks, Ulf, but for me it was pin 48, if I remember correctly.
The cable runs from the 2-pin connector on the transmission to the motor control unit, using a yellow/green wire.
I've now replaced the cable up to the generator regulator, and now there are no more problems. Now, the generator load is also showing again in the MWB16/1 icon_biggrin.gif.
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Passat 3BG Fault Code Generator for Mechanics Electrical Systems, Vehicle Electronics, Multimedia
No new posts Generator Workshop + Noise Cancelling Roll -> Free... Transmission, Chassis, Body & Interior
No new posts Yanmar Intake Noise Reduction: 412cc 1-Cylinder Generator Diesel Engine Technology
