Alarm System: How to Configure Interior Sensors
klemmi 2
Post16-06-2009, 12:23    Subject: Alarm System: How to Configure Interior Sensors Quote
Hello everyone, I have a question about the ultrasonic sensors in my car alarm system. Is it possible to adjust the sensitivity using VCDS? The car is an Audi A4, type 8H, engine ASN, convertible, manufactured in 2003.
You're very welcome, Jürgen.
Translated on 21-10-2026, 13:02.
Post16-06-2009, 14:01    Subject: Alarm System: How to Configure Interior Sensors Quote
Hello Jürgen,
Do you have a part number for the relevant control unit?
It should go through adaptation channel 45 of the control unit. Just use VCDS to access it.
Translated on 21-10-2026, 13:03.
klemmi 2
Post17-06-2009, 13:16    Subject: Alarm System: Protect Your Home Now Quote
Hello, the engine control unit number is: 8HO 959 433 D, with coding 06666.
Jürgen
Post17-06-2009, 17:38    Subject: Alarm System: How to Configure Interior Sensors Quote
You're in the wrong forum... please read my previous post again.
Translated on 21-10-2026, 13:04.
klemmi 2
Post18-06-2009, 9:44    Subject: Indoor Sensor: Monitor Temperature & Humidity Quote
Hi, unfortunately, Rainer got there first. I found it and set it to 85, and I hope that's enough. Thanks again for the answers.
Jürgen.
Post18-06-2009, 9:45    Subject: Alarm System: How to Configure Interior Sensors Translating...
[Translating...]
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Alarm System Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Lupo 6X Alarm System On-Board Diagnostics (OBD)
No new posts Alarm System Error: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Car Alarm System for Golf R32 On-Board Diagnostics (OBD)
