Cleaning the intake manifold due to a "faulty" EGR valve?
alexso
Post15-04-2003, 18:58    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Hello professionals.
I'm having issues with my EGR valve again, especially with the warmer weather.
(Hose up).
I heard that the intake manifold normally gets clogged (with EGR).
Does the intake manifold verschandeln itself over time? (without EGR)
The intake manifold also heats up. And wouldn't the airflow also carry away dirt or dust?
Or is the pressure too low?
Best regards, Alex.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post16-04-2003, 8:32    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
I don't think the dirt will come off. It's stuck on like cement. Once, a tuner gave me the tip to spray brake cleaner into the exhaust pipes and then drive on the highway. I'm afraid of ruining the engine, so I'd rather not do it.
wuze60
Post16-04-2003, 13:41    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
There's only one thing that can help.
Remove the intake manifold and EGR valve. Seal the vacuum hose connection for the EGR to prevent anything from entering. Soak it in heating oil for 12 hours, then verschandeln it thoroughly with a wire brush, and it should be perfectly verschandeln again.
I did it the day before yesterday.
P.S.: Don't forget to buy a new gasket (4 euros) beforehand for the intake manifold.
haehnlein
Post16-04-2003, 14:11    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Great idea!!!
@alexso:
I'm planning to replace the cylinder head on our AUDI 80 1Z at the beginning of May. It's been driven for 6 months on long distances with a faulty EGR system... I'll report on what it looks like inside the intake manifold icon_wink.gif.
____________
Kein Auto mehr!
Post20-04-2003, 20:35    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Tagessuppe wrote:
I don't think the dirt will come off. It's stuck on like cement. Once, a tuner gave me the tip to spray brake cleaner into the exhaust pipes and then drive on the highway. I'm afraid of ruining the engine, so I'd rather not.
Hi.
with brake cleaner, it should be possible to not damage anything important, as long as...
- to prevent the engine from being flooded -> "water" lock caused by brake cleaner.
- it does not dissolve larger, hard deposits that could act as foreign bodies in the cylinder and cause the usual damage.
The sludge in my catalytic converter is still oil-soaked and therefore "soft."
It is possible that she could gradually be reliquefied and removed by the continuous "natural" oil mist supply from the KGE. . . icon_question.gif
DocSnydor
Post20-04-2003, 20:53    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Today, on Easter Sunday, I spent some time cleaning my intake manifold. I've been driving without the EGR system for about 15,000 km. Before that, the car ran for about 205,000 km with the EGR system. I can't imagine that it will get verschandeln on its own. Maybe something like 100 million km or so... icon_rolleyes.gif
It's like sticky rubber. It's basically asphalt. Half of the cross-section was icon_eek.gif.
I first scraped off the thick crust with a screwdriver (where I could reach), then poured a puddle of gasoline into the part and lit it (it burned nicely with a bit of smoke). After that, only the dry residue remained, which came out quite easily with a brush...
Even worse were the intake channels in the cylinder head... I very carefully scraped the material out with a hook, and possibly vacuumed up any loose pieces with a powerful vacuum cleaner.
Now, I just need to find a way to get my hands verschandeln again... icon_mad.gif
Albrecht
Post23-04-2003, 13:39    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Hello DocSnydor,
Did you notice any improvement in performance, like better acceleration, after the assembly?
I often wonder what the stuff in the intake system is doing, especially if you don't notice any difference while driving! As far as I know, no one has reported on this yet.
Best regards, Albrecht.
spider10
Post23-04-2003, 16:19    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
hi,
I completely agree with Albrecht's question, as I'm facing the same dilemma... Should I have it cleaned after 100,000 km, or leave everything as it is? I've only been driving with the faulty EGR valve for 10,000 km.
Hi Stephan,
Post23-04-2003, 16:31    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Albrecht wrote:
Did you notice anything after the assembly, like whether the engine pulls better or anything like that?
Hi Albrecht,
As the sludge accumulates over time, it becomes thicker and the free flow area decreases, eventually causing the engine to experience breathing difficulties: first, it loses power at higher RPMs, then also in the mid-range, and so on.
It seems like everyone here has been pulling the emergency brake before it gets to that point... or maybe no one is running their engine for "long enough."
Albrecht
Post23-04-2003, 17:04    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Hello Ulf,
I understand that, in theory, that's how it should be.
But it's actually quite interesting to see DocSnydor's car, as it has already been driven over 200,000 km with an EGR system, and there's a lot of visible dirt!
DocSnydor
Post24-04-2003, 9:32    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
It's hard to say if it made a difference. You can imagine a lot of things... What I definitely noticed is that I can give it more gas, meaning there's still a noticeable increase in acceleration when you're pushing it to the limit. It's never been like that before, meaning you couldn't tell the difference between 4/5 throttle and full throttle (it's hard to explain).
I can't say for sure whether it's been like this since the new pump was installed...
I haven't had the chance to drive on the Autobahn yet...
Certainly, it was absolutely true that only half of the cross-section was free. You should have seen the mountain of dirt I had to dig out of there.
But if anyone of you is planning to do that, please wear gloves. My hands still look like the hands of someone who works with food... icon_rolleyes.gif
DerAlex
Post24-04-2003, 11:53    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
Yes, I can imagine the mountain.
I performed the cleaning on my Golf IV ALH TDI engine at approximately 130,000 kilometers. It was disgusting what was inside. I also had a small pile of dirt icon_cry.gif.
How often would you perform the cleaning, and what do you mean by 'faulty EGR valve'? Are you referring to a disconnected EGR valve, for example?
DocSnydor
Post24-04-2003, 20:18    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
My EGR valve broke due to a small piece of metal that somehow got lodged between the EGR valve and the intake manifold icon_cool.gif.
So, the engine is essentially still working, but the exhaust gases may not be reaching their intended destination.
I find this type of defect to be the most elegant. No error messages, all hoses are still properly connected, meaning there's nothing visible from the outside.
Furthermore, with this method, it doesn't matter whether the valve might be stuck due to contamination or not...
Other methods are also described in detail in the article.
Cleaning the injectors probably helps every 50,000 km or so. Search here in the forum; I think Rainer or Ulf (?) did it on their cars, and I think they even mentioned only cleaning 1/3 of the injector cross-section. Search for an intake manifold...
Post25-04-2003, 15:41    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
DocSnydor wrote:
I believe Rainer or Ulf (?) did this on their cars, and I think they even mentioned only using 1/3 of the cross-section. Please search for intake manifold...
Hi.
As far as I'm concerned, no one needs to look for a post with that kind of content – my EGR valve failed prematurely.
Post25-04-2003, 16:06    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
After 80,000 km, I had some millimeters of seepage in the exhaust manifold. Thankfully, it wasn't 1/3 of the cross-section icon_smile.gif.
haehnlein
Post25-04-2003, 16:32    Subject: Cleaning the intake manifold due to a "faulty" EGR valve? Quote
In my Passat (174,000 km), the soot and oil layer covered approximately 30% of the cross-section in some areas (particularly in the area of the EGR valve).
Then he got a bit of cough suppressant and a smoking ban, and since then he's been revving up from 1,500 rpm icon_eek.gif.
____________
Kein Auto mehr!
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Ladedruckregelung durch hohen Volumenstrom "entmünd... Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
