v6 TDI quattro, rear differential input shaft bearing broken?
quattrotdi
Post26-04-2003, 19:14    Subject: v6 TDI quattro, rear differential input shaft bearing broken? Quote
Hello!
I have an Audi A4 Avant TDI V6 (AKN) Quattro, manufactured in 6/99, with 97,700 km.
It is likely that the bearing in the rear axle differential, on the side where the driveshaft enters, is broken.
1. Who knows if, in this case, Audi will take over the repair (or possibly a new differential) under warranty?? (The service book is complete).
2. Has anyone perhaps already swapped this gearbox, and does anyone know how to demonstrate it, i.e., whether the entire differential needs to be disassembled?
or whether this unit can be replaced from the outside (on the cardan shaft side)?
Thank you very much for your help!!!
hd
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter T4: Rear Door Lock Malfunction Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is this true for Audi quattro? Transmission, Chassis, Body & Interior
No new posts A4 2.5 V6 TDI: Loud Exhaust Sound (B5 Quattro) Diesel Engine Technology
No new posts turbocharger for Audi A6 2.5 TDI Quattro (4th generation) Diesel Engine Technology
No new posts Automatic shift timing programming for Audi A6 quattro On-Board Diagnostics (OBD)
