Generator Werkstatt + Geräusche Spannrolle -> Freilauf ? | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Devilseye503
Post11-07-2009, 12:09    Subject: Quote
and eventually, it will probably also damage your drive, because it was already dancing up to 1-2cm in idle for me.
icon_eek.gif Is this really that bad? My car has been doing this since it was first delivered icon_rolleyes.gif
Post11-07-2009, 16:46    Subject: Quote
I can't tell you, my previous one didn't work, and the one I replaced it with is also running very smoothly. Of course, it moves, otherwise it wouldn't have any purpose. But only minimally....
Post11-07-2009, 20:54    Subject: Quote
Devilseye503 wrote:
and eventually, it will surely also disassemble the spanner, because it was already dancing about 1-2cm in idle.
Even with estimated 100 Hz?
Believe me, you can hear it. This is a different story than the 1-2 times per second with intact free running.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post17-07-2009, 22:41    Subject: Quote
Do you really mean:
The 4-cylinder engine never really runs smoothly, but instead accelerates at each cycle, then falls off and accelerates again. When a rigid connection is used with the LiMa, it will increase its tendency to escalate.
Should we instead attribute this solely to the diesel engine, given its high injection pressures and compression? That's a big problem, everything that's connected to the diesel KW "must be dampened and balanced."
I have never seen a gasoline engine with a free-running alternator.
reflexsilber met.
Post18-07-2009, 10:13    Subject: Quote
I've never seen a car with a free-running alternator before.
At least with the 4-cylinder engines, this connection seems to be implicit.
Heavy Limas (120 A) are having a blast.
Heavy limas have overtaken diesels.
icon_arrow.gif Diesels have a natural tendency to accelerate.
Post18-07-2009, 10:36    Subject: Quote
nope....my Golf has a 90A alternator...and a free-wheel, which was broken (due to the Holland version...I don't have coolant heating)
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Tensioner Mounting Nut Workshop Deal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG Fehler Generator Werkstatt Electrical Systems, Vehicle Electronics, Multimedia
No new posts MFA: "Stopp Generator Werkstatt" bei 120km/h Diesel Engine Technology
No new posts Loud ZR tensioner Diesel Engine Technology
No new posts BMR KRR tensioner squeaks Diesel Engine Technology
