Speed "frozen" at ~1200
Schöner_als_Golf
Post24-07-2009, 18:13    Subject: Speed "frozen" at ~1200 Quote
Hi!
Recently, while accelerating in third gear, the RPM of my TDI engine (engine code ASV) got stuck at approximately 1200 RPM. No matter how much I pressed the accelerator, it wouldn't go any higher. However, when I released the gas pedal and disengaged the clutch, the engine didn't drop to idle speed; the RPM simply remained "stuck" at 1200 RPM.
After turning it off and on again, the problem was fixed, and I didn't think about it anymore. However, the same thing happened again just now, and twice in a row.
The error memory is like an empty bottle.
"I'm sorry, but I don't have any information about that."
Here are some other ways to say "I'm sorry, but I don't have any information about that":
* "I'm afraid I can't help you with that."
* "Unfortunately, I don't know anything about that."
* "I'm not sure how to answer that question."
* "That's a good question, but I don't have the answer."
* "I'm sorry, but I can't provide you with any information on that topic."
I hope this helps!
Translated on 15-07-2026, 22:09.
DieselBär30x
Avatar-DieselBär30x
Post25-07-2009, 10:30    Subject: Speed "frozen" at ~1200 Quote
Hello there, handsome!
I can't imagine that your error memory is clear given this kind of error.
To my knowledge, the fixed engine speed is selected by the engine control unit when a problem with the throttle position sensor is detected.
It would be interesting if it were possible to read out the measurement data blocks of the engine control unit for "driver requests" even in the event of a fault.
Best regards from Munich!
Translated on 15-07-2026, 22:11.
Benni
Post27-07-2009, 10:23    Subject: Speed "frozen" at ~1200 Quote
Yep, that's the accelerator pedal.
Ist es ein passat? hatte das gleiche Problem, der Geber ist sehr Feuchtigkeitsempfindlich... bei mir warens so knapp 10 Liter Wasser im Fussraum. icon_wink.gif
It fell off the (new) windshield.
Translated on 15-07-2026, 22:12.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts RPM and "Glow Coil" in Basic Settings Diesel Engine Technology
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Slight jerking during RPM drop from 1200 to 900 RPM Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
