Hi everyone,
I installed a fixed tow hitch on my father's 1999 Galaxy 1.9 TDI (81kW).
Everything went smoothly, and the installation of the electrical wiring was actually quite easy.
The description now states the following:
Activating the additional indicator light:
The additional indicator light for trailer operation is vehicle-side.
already available and pre-packaged.
To do this, the vehicle's own control unit or multifunction unit must be connected to a special...
V.A.G. service testers (type 5051, 1551, 1552) or with the Ford FDS 2000 test system.
The system should be parameterized according to the body/self-diagnosis guide after the installation of the electrical wiring harness.
The additional indicator light for trailer operation will then be activated.
=> I've already installed a gasoline particulate filter (GPF) on the car and unlocked it using a VAG diagnostic tool.
but how and in which vehicle system should I activate the trailer control light?
is completely beyond my knowledge...
I think it can actually only happen in combination (17), right?
Hoping for your help...
Greetings, PD90.
(who doesn't want an AHK in his G5!)
Translated on 31-08-2026, 11:49.
