dokatoto wrote: |
| Can someone tell me what the DF clamp is for? |
Hi Thorsten,
It reports the alternator's load to the engine control unit. If the load approaches 100%, it deactivates the glow plug heating to prevent the vehicle's voltage from dropping (initially).
DF is therefore only important in winter - I don't know of any other meaning.
Quote: |
| And which pin of the 80-pin control unit does the DF signal come from, and what is the cable color? Perhaps someone has a wiring diagram handy right now. |
Here's something about a Golf 4 / Bora: Pin 22 is brown-red.
Whether that also fits the Passat:
Tip: Measure the resistance to ground at the engine computer connector (hopefully something will be displayed), then disconnect the alternator connector. If the measured value changes, you have found the DF terminal
Thank you and best regards.
