Hello, I did a engine swap on an Audi A6 2.5TDi, year 07/2003, from a BDG to an AYM engine, and the fuel injection pump worked fine .
"I've only just exceeded the EGR valve regulation limit. How can I fix this? Or does the BDG model have a different EGR valve?" Can anything be recoded there?
Best regards, Janek.
The BDG (likely referring to a specific engine component) has a cooled EGR (Exhaust Gas Recirculation) system and a throttle valve to increase the EGR rate when necessary. Do you still have the BDG control unit installed?
