Audi A4 2.5 TDI Turbo Lag: Why It Happens?
bummisz
Post24-10-2009, 16:48    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
Normally, I would experience the "boost" or increase in power at approximately 2000 RPM. Below 2000 RPM, there was absolutely nothing – then suddenly, it would kick in properly.
Two months ago, the mass airflow sensor (MAF) was replaced, but it barely provided more power and produced a lot of black smoke.
After replacing the mass airflow sensor, everything worked perfectly for about 3 weeks!
Now the power doesn't kick in until around 2700 RPM, and it's not as sudden as before.
I did a log using VAG-COM today.
It would be great if you could take a look at this. Maybe you'll notice something. There are no errors in the "engine electronics" fault memory. Unfortunately, I don't have enough technical expertise to properly interpret the log data...
Log:
[Edit Admin: Wenn Du hier Hilfe erwartest, solltest Du Dein Log auch hier zur Verfügung stellen.]
Here's the link to the Screenshot, and below it is the log from VAG-COM.
/viewtopic.php?p=156319#156319
Translated on 28-07-2026, 10:57.
bummisz
Post24-10-2009, 18:19    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
Does your phpBB forum have the ability to upload files?
Translated on 28-07-2026, 10:59.
Post24-10-2009, 18:24    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
Okay, I'm ready. Please provide the German text you want me to translate into English.
bummisz
Post27-10-2009, 12:58    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
In the log diagram, you can see that when the engine is running at full throttle, the mass airflow (MAF) value fluctuates quite a bit, and so does the turbo pressure. Is this normal, or should the MAF value be consistently above 750mg/s when running at full throttle?
Translated on 28-07-2026, 11:00.
bummisz
Post03-11-2009, 15:05    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
I've only uploaded two screenshots of log data from two different runs: one with an LMM that is 4 weeks old, and one with a brand new one.
LMM is...
Turbo pressure is...
Accelerator pedal.
Engine speed is...
Is this fluctuation in boost pressure and mass airflow rate normal?
Translated on 28-07-2026, 11:01.
Post03-11-2009, 16:21    Subject: Audi A4 2.5 TDI Turbo Lag: Why It Happens? Quote
Should the value from the mass airflow sensor (MAF) be constantly above 750 mg/stroke at full throttle?
Actually, yes!
Translated on 28-07-2026, 11:02.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 2.5L TDI AKE - Performance issues, later turbo Upload
No new posts A6 2.5L TDI AKE - Performance issues, later turbo On-Board Diagnostics (OBD)
No new posts Climate control motors Audi C4 / BOSCH motor, also later ... Transmission, Chassis, Body & Interior
No new posts Full throttle only when the oil is warm? Gasoline Engine Technology
