Frankk
07-08-2009, 20:33 Subject: Polo 9N: Adjust Service Interval Settings |
Hello!
My parents own a 9N 1.9 TDI 74kw (AXR) from the year 2003. The problem is that the settings for the service interval display are completely messed up. The issue started when an independent workshop, during an oil change, changed the interval setting from "flexible" to "fixed." When it was time for the next oil change, I tried to revert the changes using VAG-COM / VCDS, but I wasn't entirely successful.
Today I changed the oil again (after approximately 20,000 km). Afterwards, I wanted to reset the service interval display using VCDS. There's a function in the main menu called "Service Reminder Interval Reset" or simply "SRI Reset." However, after the program connected to the control unit, it displayed a message stating that my control unit with part number [...] is not supported and then stopped. Consequently, I will have to reset the individual entries in the control unit myself using adaptation.
Therefore, I urgently need your help. I would be extremely grateful if someone could go through all the channels with me one by one so that everything is finally correct: A) The extended maintenance interval/long-life oil setting, and B) the reset after an early oil change.
I would really appreciate it if someone could check what the channels of the StG (likely referring to a specific device or system) should look like.
If it helps, I'll post here a summary of the messed-up settings as they are currently stored in my STG. [size=85](The information is from OpenOBD.org)[/size]
Quote: | -> Channel 39 (TOG sensor) (only with WIV).
Deactivation of the temperature and oil level sensor (TOG).
0 - disabled.
1 - activated
IS = 1 (correct???).
-> Channel 40 (distance since last service) (from model year 2000 onwards).
This value indicates the distance traveled since the last service, measured in kilometers.
Changed during the oil change from 192 to 0.
-> Channel 41 (Time since service).
This value indicates the number of days since the last service.
Changed during oil change from 444 to 0.
-> Channel 42 (Minimum distance to oil).
This value indicates the minimum distance to the next oil change, specified in kilometers.
00015 - not long-life.
Is = 150 (Correct? Or should it be Value = 15?!)
-> Channel 43 (Maximum distance to oil).
This value indicates the maximum distance (in kilometers) that can be driven before the next oil change is required.
300 - Gasoline engines (long life).
500 - Diesel engines (long life).
Is = 500
-> Kanal 44 (Max. Time until service).
This value specifies the maximum time until the next service, measured in days.
00365 - Not a long-life product (12 months).
00730 - Extended Warranty (24 months)
Is = 730
-> Channel 45 (oil quality)
1 - Fixed maintenance interval.
2 - Flexible maintenance interval.
Is = 2
-> Channel 47 (exhaust leak) (diesel only).
The displayed value is a reference value for the service indicator. The shown value is a calculated value representing the amount of soot in the engine oil, based on a distance of 100 kilometers.
Is = 286 Question: Should I set the value to 0 after the oil change? Or is "286" a kind of "multiplier" that shouldn't be reset?
-> Channel 48 (thermal load) (diesel only).
The displayed value is a reference value for the service indicator. The shown value is a calculated value representing the thermal stress on the engine oil, based on a distance of 100 kilometers.
Is = 150. Same question: After the oil change, should it be set to "0" or left alone?
Channel 49 (minimum time interval).
The time is given in days.
365 - Fixed maintenance interval (12 months).
730 - Flexible maintenance interval (24 months).
Is = 365
You are my last hope. Of course, I've already tried using the search function, but unfortunately, I haven't found anything regarding the 9N model. Maybe someone here owns a 9N and can post the corresponding entries from their Polo. *hopeful*
Frank.
Translated on 10-08-2026, 11:40.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
07-08-2009, 20:45 Subject: Polo 9N: Adjust Service Interval Settings |
Which version of VCDS are you using? The 9N should be compatible with the assistant function.
Translated on 10-08-2026, 12:04.
Profile PM WWW Garage |
Frankk
07-08-2009, 21:01 Subject: Polo 9N: Adjust Service Interval Settings |
Good evening!
I just installed version 907.3. That should be the latest version, I think.
Frank.
Translated on 10-08-2026, 12:05.
07-08-2009, 22:47 Subject: Polo 9N: Adjust Service Interval Settings |
0 - disabled.
1 - activated
Okay.
Okay.
Okay.
Incorrect, 15 is the correct answer.
Is = 500
According to what's written there, it's actually correct. However, it should actually be 50, because 50 x 1000 km = 50,000 km. Please double-check carefully. If it were 500, then it would be 500,000 km.
Is = 730
Okay.
Is = 2
Okay.
Incorrect; must be set to 0. The control unit will recalculate it.
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Is = 365
Incorrect, 730 is the correct answer.
| MfG. Michael
Translated on 10-08-2026, 12:17.
Profile PM Garage |
Frankk
08-08-2009, 10:43 Subject: Polo 9N: Adjust Service Interval Settings |
Hello Michael!
Thank you for your reply. I just went back to the car and reset the soot entry and thermal load values to zero. After that, I checked channels 42 and 43 again:
Kanal 42 = Min. Distance to the oil field.
Kanal 43 = Max. Distance to the oil field.
Okay, something isn't right. According to OpenOBD.org, you should take the stored value x 1.000. However, VCDS sees it differently: It displays the text "Channel Description" (or whatever the official name is) at the top.
(Channel 42) Minimum oil level at 100 km.
(Channel 43) Maximum oil value within 100 km.
So, if I'm to trust VCDS, then channel 42 (minimum distance) should be 150 and channel 43 (maximum distance) should be 500. Personally, I now believe that the factor of 100 from VCDS is actually correct, and there seems to be a consistent typo in OpenOBD. This is also supported by the description in OpenOBD, which states: "If channel 42 = 15, then LongLife is deactivated." As mentioned, according to VCDS, it should be "150".
And on channel 43, the value of 500 would perfectly match (500 x 100 = 50,000).
Do you understand what I mean?
And then I have another question: As you've corrected the numbers now, Channel 44 represents the maximum time until service.
Kanal 49 = Min. Time until service.
the same value = 730.
Isn't that contradictory? Logically speaking, wouldn't that mean the service indicator always lights up exactly every 730 days?! What's "flexible" about that then?!
Frank.
Translated on 10-08-2026, 12:26.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
08-08-2009, 16:00 Subject: Polo 9N: Adjust Service Interval Settings |
Typically, things are structured like this within the corporation:
-> Kanal 42 (Min. Performance)
Minimum value of mileage at intervals of 1000 km.
-> Kanal 43 (Max. Performance)
Maximum kilometers per charge, displayed in increments of 1000 km.
-> Kanal 44 (Max. Time.
Maximum time interval in days.
*edit* 73 for 730 days.
However, I'm not entirely sure about the specific dates... at least, that was the case with the older models.
Ideally, the channels should also adjust themselves if you use long-life oil.
"You set it up and then reset the service... (channel 2 to '0')"
Then you should be able to see the correct values.
Translated on 10-08-2026, 12:30.
spiderschwein
Joined: 10/17/2009 Posts: 8 Karma: +0 / -0 Location: Bottrop 2003 Volkswagen Polo Free account, no CAN development support
17-10-2009, 13:01 Subject: Polo 9N: Adjust Service Interval Settings |
TDI-GTI-4-Motion wrote: |
Is = 365
Are you sure that the information on OpenOBD and in the label file from VCDS is correct?
The longlife interval for the Polo 9N TDI is typically between 15,000 and 50,000 km or 1 to 2 years.
If you enter 730 as both the minimum and maximum time interval, does the AI assume a fixed period of 2 years and only calculate the kilometers based on that assumption? Gruß Kimi
Translated on 10-08-2026, 12:32.
Profile PM Garage |
17-10-2009, 22:01 Subject: Polo 9N: Adjust Service Interval Settings |
spiderschwein wrote: | | Are you sure that the information on OpenOBD and in the label file from VCDS is correct? |
I'm assuming that, however, I didn't write that into the label file myself.
Your line of thought is correct, but not fully developed. What do you do when you have a driver who racks up 50,000 kilometers in 8 months? Do you understand what I mean by that?  MfG. Michael
Translated on 10-08-2026, 12:34.
Profile PM Garage |
spiderschwein
10-11-2009, 1:52 Subject: Polo 9N: Adjust Service Interval Settings |
TDI-GTI-4-Motion wrote: | Are you sure that the information on OpenOBD and in the label file from VCDS are correct? spiderschwein wrote: |
What do you do when you have a driver who racks up 50,000 km in 8 months? |
In that case, you would have to take the car for servicing after just 8 months because the 50,000 km mileage limit would be reached first.
As soon as I have a VCDS system, I'll check what the factory default coding is and report back. | Gruß Kimi
Translated on 10-08-2026, 12:36.
Profile PM Garage |
