Passat 3C Rear Brake Adjustment Procedure
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
View previous topic
View next topic
Author
Message
vwSchrauber
06-11-2009, 11:01
Subject: Passat 3C Rear Brake Adjustment Procedure
Quote
Brake adjusted to default setting, bleed valve (MWB) 007 opened, brake caliper removed.
Now the question arises: how do you reset the piston?
Does it connect via threads, as was common in older systems?
"Thank you."
Greetings.
John.
Translated on 07-08-2026, 0:48.
Profile
PM
vwSchrauber
06-11-2009, 12:05
Quote
It's been taken care of.
After some trial and error, it could now be adjusted with a feel for the right amount of force, and then locked into place.
Threads, as usual
Translated on 07-08-2026, 0:49.
Profile
PM
Arne
09-11-2009, 12:13
Quote
Yes, you can easily revert to the previous setting. For example, with the A8, you still have to manually enter the pavement thickness later, but with the A6, that's not necessary. I don't know about the Passat right now.
Greetings.
Translated on 07-08-2026, 0:50.
2002 Volkswagen Golf
09-11-2009, 12:47
Quote
Arne wrote:
...that doesn't apply to the A6. I don't know about the Passat right now.
Exactly. Just set the basic settings at the end, and you're done.
VW Golf IV
TDI GTI 4
-Motion Bj.2002 MKB/GKB: ARL/FEK
VW T4 Pritsche TD
I
Bj.1999 MKB/GKB: AXG/AFK
(Selfmade)
Profile
PM
Garage
bloesch
Quote
small note / brief comment.
For models with the electric parking brake, the piston (like on the front) can be retracted. It doesn't need to be rotated.
Translated on 07-08-2026, 0:51.
Profile
PM
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Golf 1J: Rear Clicking Noise - Diagnosis & Repair
Workshop action Polo MJ 2000, rear brake hose
Golf 1J Repair: Rear Hatch Lock Problems
Rear Door Panel Passat 3B
VW Passat Rear Door Won't Open - Fix!
Passat Variant - Rear bumper, assembly
Passat 3B Rear Shock Absorber Torque Specs
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.053s
