VW Touran 2.0 TDI stottert | Posts 16+
Go to page: Previous  1, 2
Steffen W
Karma: +104 / -0   Thank you, like it!
Post13-11-2009, 20:30    Subject: Quote
GolfMeister wrote:
Only cylinder 4 sometimes goes up to 100. According to the GFS (presumably a gauge or specification), everything is okay up to 125.
You've already answered your own question with that. Possible cause: a stuck positive electrode displacement (PDE). Possibly eaten.
The target for GDP growth is approximately +/- 100.
Passat Variant BGW 2005
Translated on 22-09-2026, 22:15.
lichti
2007 Volkswagen Golf
Post16-11-2009, 12:02    Subject: Quote
I would start by replacing the fuel filter. Since the tandem pumps tend to leak slightly, some oil inevitably gets into the fuel.
In the acceleration range (when the accelerator pedal is pressed), the filter closes.
The jolting is quite noticeable, but it can be stronger or weaker at times.
So, my tip: fuel filter!
"Lg" is a German abbreviation that stands for "Liebe Grüße," which means "Best regards" or "Warm greetings" in English.
EX-Golf V GTI Edition30, Oettinger Abgasanlage - Chiptuning
EX-3BV Passat Variant Business Comfortline, AVB, Bj. 2003
6J1 Seat Ibiza Cupra, CAVE, Bj. 2010
Translated on 22-09-2026, 22:16.
GolfMeister
Post16-11-2009, 23:28    Subject: Quote
I already replaced the filter, but it didn't work.
It wouldn't really make sense if the car jerked at engine speeds up to 3000 RPM, but then ran smoothly above 3000 RPM, even on the highway at 200 km/h without any problems. Especially at those speeds, it needs a lot of fuel.
But still, thank you for the information!
Translated on 22-09-2026, 22:17.
Steffen W
Post17-11-2009, 14:48    Subject: Quote
lichti wrote:
I would start by changing the fuel filter! So, my tip: fuel filter!
Best regards
Then, instead of a single PDE increasing GDP by +100, all four would decrease it uniformly.
Translated on 22-09-2026, 22:18.
schrauber2904
Post22-11-2009, 19:59    Subject: Quote
Hello, I would like to remove the PDE (presumably a component) from the 4th cylinder and take a look at the cylinder head walls. Due to friction from the seals, wear marks can occur, which can then lead to leaks. If those are in order, I'll warm up the vehicle properly and remove the intake manifold to check if there is any water (coolant) in the intake channels of the cylinder head. (It wouldn't be the first cylinder head to crack.)
Translated on 22-09-2026, 22:19.
Steffen W
Post22-11-2009, 21:18    Subject: Quote
internetnihat wrote:
The wiring harness is approximately 4 months old, and the values in the mwb 23 are all negative when it vibrates, which proves that there is nothing wrong with the cable.
That is not proof.
DOES ANYONE KNOW IF I CAN SUBSTITUTE THIS PART WITH A DIFFERENT ONE, AND WHICH PART IS IDENTICAL TO 03G130073BX?
VW constantly changes the part numbers for the same part.
MFG NIHAT
Bosch 0986 441 530 as a replacement part.
also
03G130073B
and
03G130073
Translated on 22-09-2026, 22:20.
mechanics77
Post25-11-2009, 22:49    Subject: Quote
Well, you've probably heard many suggestions already... here's mine.
Problem located on cylinder 4.
Expand all PDEs and inspect the direct connection of the PDE (copper ring) to the head!
"No uniform impressions. Replace the head!!!!"
"Seat is okay. Clean the PDE (pre-combustion chamber) preventatively to remove carbon deposits using an ultrasonic cleaning device."
It costs approximately 40 euros at a VAG workshop to have the common rail injectors (PDEs) tested when they are removed.
"There's a slight scratch in the upper area of the cylinder head, but it's not serious. It can be removed using fine-grit sandpaper or abrasive cloth! (Important: This is to prevent damage to the new seals when installing the high-pressure fuel pump!)"
Check the camshaft and lifters for increased wear and damage!!!!
If everything is okay... swap the ignition coils from cylinder 1 to cylinder 2, and from cylinder 4 to cylinder 3!
Adjust the collision parameter of the PDE precisely!
Set the camshaft synchronization angle precisely to 0, or slightly negative.
Test drive and reassessment of complaints.
If the value for cylinder 4 has changed from 2.99 to 3, then it may only be necessary to replace the PDE (presumably a sensor or component). If the value of 2.99 remains on cylinder 4, then the cylinder head needs to be replaced.
Cylinder 1 is okay... it's only matching the problem on cylinder 4...!!!!
Translated on 22-09-2026, 22:23.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z stutters Diesel Engine Technology
No new posts AKF Stuttering: No Gas Intake - Troubleshooting On-Board Diagnostics (OBD)
No new posts Golf 3 TDI sometimes stutters under full load? Diesel Engine Technology
No new posts Golf 3 TDI: Stuttering/Misfiring When Idle Diesel Engine Technology
