Squeaking Noise: Causes and Solutions
histe
Post05-05-2003, 18:51    Subject: Squeaking Noise: Causes and Solutions Quote
I have a Golf IV TDI PD that is now three years old. Since the weather has been so hot, it's been squeaking like an old wheelbarrow. It's really awful, especially when driving over even the smallest bumps. Is there anything I can do about it, like spraying something? If so, where exactly should I spray it?
It's barely tolerable... he didn't used to do that before!
Thank you, Histe.
Translated on 01-10-2026, 23:51.
donalexo
Post05-05-2003, 23:27    Subject: Squeaking Noise: Causes and Solutions Quote
Hello Histe!
Welcome to the club of squeaking suspensions. My A3 had the exact same problem. It started for me after about 3 years.
The noise only occurred during warm and dry weather conditions.
Check out this post:
After the grease treatment of the described rubber mounts, a significant improvement icon_wink.gif in the noise level occurred.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 01-10-2026, 23:52.
histe
Post06-05-2003, 6:58    Subject: Squeaking Noise: Causes and Solutions Quote
Hi Alex... Thanks, that helps a lot... Could you send me the picture of Andreas?
If you still have it?
Thank you.
Hoist.
Translated on 01-10-2026, 23:53.
donalexo
Post11-05-2003, 23:21    Subject: Squeaking Noise: Causes and Solutions Quote
@histe:
Okay, I mainly treated the rubber bushings of the stabilizer bar coupling with grease spray. Be careful here that nothing gets onto the brake discs. It's best to let it soak in (capillary action!) and then wipe off any excess grease from the outside, so that it doesn't somehow end up near the brakes.
I also sprayed grease onto the rubber bushings located between the mounting brackets and the stabilizer bar on the underside of the vehicle, specifically on the lower control arms.
I recently read a post in this forum where a G4 driver had new, i.e. modified, mounting brackets and rubber bushings installed for the anti-roll bar. Perhaps that's the best long-term solution?
As I mentioned before, the noise level has improved significantly, but I still think you can hear a slight noise under dry and warm weather conditions. However, this is only noticeable with the radio turned off and the side window open.
If you want the image, you need to provide me with your email address. Unfortunately, I don't have my own website to provide you with a link.
Alex.
Translated on 01-10-2026, 23:55.
histe
Post12-05-2003, 12:19    Subject: Squeaking Noise: Causes and Solutions Quote
hi alex,
I already received a picture and instructions from Denis last week and did it on Saturday... it's basically the same as what you did... the leaves seem to be disappearing... let's see how it changes when it gets warmer... talk to you later!
Hoist.
Translated on 01-10-2026, 23:56.
No new posts Drum Brake Squeal: Causes & Fixes Transmission, Chassis, Body & Interior
