amiernie wrote: |
The ABS and ESP lights are constantly turning on, not always at the same time, but mostly. The car drives as if it's being braked / power loss (I was driving on icy roads with temperatures between -8 and -10 degrees).
Have you ever taken a look at the instruction manual?
That's intentional!
If the electronics detect differences in wheel speeds or wheels spinning too quickly (which should normally occur on smooth roads), it will reduce power or brake individual wheels.
Quote: |
Where are the sensors?
Protected within the wheel hub.
Quote: |
Could they be traveling? |
No. Not usually. They operate inductively and are not easily affected by even the most significant environmental factors. It could only become critical with metallic contamination.
