K-Lines: Two Ships Collide
golf-vw
Post14-05-2003, 15:57    Subject: K-Lines: Two Ships Collide Quote
Can anyone tell me which current vehicles on the market have two K-lines?
We now have a Phaeton here at the university. Does it already have two K-lines?
I assembled the adapter with two K-lines and it works well with one. Now I have a question about the other K-line.
Translated on 23-10-2026, 11:03.
Cheffe
Post14-05-2003, 20:20    Subject: K-Lines: Two Ships Collide Quote
I believe it started with the two K-lines in the Audi A4.
Boss.
Translated on 23-10-2026, 11:04.
Post14-05-2003, 20:33    Subject: K-lines: Two lines explained Quote
I assembled the adapter with two K-lines and it works well with one. Now, I have a question about the other K-line.
Hi.
Connect the Phaeton now... if you've built my adapter suggestion 4.0 and the Phaeton has 2 K-lines.
(If such an electronic control unit can still manage with just 1 K-line - which car would then need 2 icon_razz.gif icon_question.gif?)
Then, depending on the specific control unit (STG), either the one or the other RXD LED should blink.
If that's the case, you know that...
- The Phaeton 2 K-Lines has...
- the separated RXD LEDs are functioning as intended.
Due to the latter, I would naturally be interested in the result icon_wink.gif.
P.S.: "Normal" engine displacement can also be replaced by a TDI icon_cool.gif.
Translated on 23-10-2026, 11:05.
No new posts Two K-Lines: Installation & Benefits Diesel Engine Technology
No new posts Turbo Failure: Twice in a Row? Diesel Engine Technology
No new posts Tiptronic A6: Gap Between Gears - Problem? On-Board Diagnostics (OBD)
No new posts VW T5 Error Codes: P0653 & P0408 Explained Diesel Engine Technology
