ABS Control Module 6X0 907 379B - Error Code 00668 (Solution)
Octavia_4x4
dieselschrauber likes this.
Post30-12-2009, 15:58    Subject: ABS Control Module 6X0 907 379B - Error Code 00668 Quote
Here are some troubleshooting tips for the error below:
Control unit part number: 6X0 907 379 B.
Component or version: ABS 30 IE CAN V004.
Software coding: 06406
"One error found:"
00668 - Terminal voltage, terminal 30.
16-10 - Signal out of tolerance - Interrupted.
ABS control unit installed in: SEAT Ibiza 6K, VW Polo 6N/2, VW Lupo, SEAT Arosa and similar models.
UNDER NO CIRCUMSTANCES should you disconnect the connector on the ABS control unit. This control unit is known to have its contact pins corrode and break off when the connector is disconnected, resulting in the need for a new ABS control unit.
The cause of the above error is:
- Battery terminal clamps are corroded. Loosen all screws and retighten them. If necessary, clean heavily rusted parts with a brush or replace them.
- Battery voltage too low (battery discharged or defective).
This allows you to avoid replacing the ABS control unit (which many workshops unfortunately recommend), saving around €800 in parts and labor costs.
Perhaps this would be suitable for technical articles? Or as a supplement to lists of error codes?
Greetings.
George.
Translated on 06-08-2026, 17:36.
Ratings - ABS Control Module 6X0 907 379B - Error Code 00668
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Diesel Engine Technology
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Help with error code On-Board Diagnostics (OBD)
No new posts Climatronic Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
