Bleed Brakes / Replace Brake Fluid Completely
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
ollli
Post03-01-2010, 22:40    Subject: Bleed Brakes / Replace Brake Fluid Completely Quote
Hello, diesel mechanics.
I installed a larger master cylinder in my Golf 2 with a TDI AFN engine.
Do I need to replace the entire brake fluid now, since air bubbles have formed directly in the brake lines near the master cylinder?
What's the best way to proceed, as I still have 5 liters of ATE brake fluid in my garage.
Best regards.
Olli.
Translated on 01-09-2026, 5:25.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post03-01-2010, 23:16    Subject: Bleed Brakes / Replace Brake Fluid Completely Quote
First, bleed the connections at the heat pump unit until liquid starts to emerge, then close them.
Then, bleed all the wheels.
How else would you be sure that there aren't any air bubbles left somewhere?
Hopefully, your kettle is in good condition and not old or unusable. If in doubt, have it tested beforehand, or boil it. icon_twisted.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 01-09-2026, 5:26.
ollli
Post03-01-2010, 23:56    Subject: Bleed Brakes / Replace Brake Fluid Completely Quote
Hello.
Thank you for the quick response. I'll start bleeding the brakes tomorrow.
Best regards and a great start to the week.
Olli.
Translated on 01-09-2026, 5:27.
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bremsanlage mit ABS entlüften Transmission, Chassis, Body & Interior
No new posts Braking system Transmission, Chassis, Body & Interior
No new posts G60 Brake Kit for AFN Engine: Installation & Review Diesel Engine Technology
No new posts Passat 170PS TDI: Brake System Details Transmission, Chassis, Body & Interior
