ABS - Kontrollleuchte geht bei über 20km/h an | Posts 48+
Go to page: Previous  1, 2, 3, 4
Deus Violentia
Post13-01-2010, 15:52    Subject: Quote
Same error --> Fuse corroded --> Cleaned, replaced, now working.
Translated on 06-09-2026, 4:27.
mserge
Post19-01-2010, 18:21    Subject: Quote
I once had a similar problem with my A4. In that case, it was the relay on the relay holder that was sticking (but only occasionally), causing the pump to run constantly. Perhaps you have a similar relay that is making intermittent contact or not making contact at all. However, I can't say whether an A3 or Golf has such a relay, as sometimes it is integrated into the control unit.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts SRS Light On After Low Voltage - LT 35 2.5 TDI On-Board Diagnostics (OBD)
No new posts ABS continuously regulates after sensor replacement while... On-Board Diagnostics (OBD)
No new posts Engine Not Reaching Operating Temp After 20km Diesel Engine Technology
No new posts GRA Light Off? Seat Altea Troubleshooting. Diesel Engine Technology
