24-01-2010, 21:44 Subject: |
Guste.
The photo of the WT is from there.
The auction ended on December 16th, and I found it by searching for "7M3 203 572 B".
Just buy one and start tinkering with it.
m; Transparency, Teamwork
Profile PM Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
24-01-2010, 22:28 Subject: |
Don't forget to install a 10-bar fuel pressure pump as a wash water pump when using the heat exchanger solution, because the heat exchanger will have pressure losses.  2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Profile PM Garage |
vwSchrauber Profi-Schrauber
25-01-2010, 12:15 Subject: |
Quote: | | When implementing a heat exchanger solution, don't forget to install a 10-bar fuel pressure pump as a wash water pump, because the heat exchanger will have pressure losses. |
Then, no inline pump should be used, because the washing device contains an electrolyte.
Quote: | So, just buy one and start tinkering with it.
That would be the most elegant and unobtrusive solution. selber schrauben - statt Werkstattpfusch
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
25-01-2010, 17:35 Subject: |
dieselmartin wrote: | | Guste, that's where the WT photo is from. The auction ended on December 16th, and I found it by searching for "7M3 203 572 B". So, just buy one and start tinkering with it. |
Hello Martin,
Okay, my question about the eBay auction number referred to the Webasto windshield washer hose that T3Surfer mentioned.
guste100 wrote: | T3Surfer wrote: | There used to be a windshield washer hose from Webasto that could be retrofitted, but it's probably not available much anymore, which might be due to the high price! There's something from Webasto in the trunk, I think.
[url][Egay Link][/url] |
Could you please post the article number? The link was probably removed by the forum software. I couldn't find it, even after searching. |
Profile PM Garage |
01-02-2010, 14:50 Subject: |
Hey...
This is another great opportunity to solder together a custom-made RIR-WT.
"They haven't produced any more of those since the T3."
The volume can then be conveniently adjusted to match "a standard shot of liquor"  .
Profile PM Garage |
ballermann
2014 Audi Q5  Free account, no CAN development support
02-02-2010, 11:51 Subject: |
goettmann wrote: | Hutfahrer wrote: | In most current vehicles, there is no way to use the engine heat to defrost. The reason is simple: the windshield washer fluid reservoirs were almost universally located between the fender and the wheel well, or somewhere in the front area near the wheel well.
Then, finally buy the five-liter car that the Green Party is demanding, and the windshield washer reservoir is located in front of the partition wall separating the passenger compartment.
Here he lies
The exhaust heat is more likely to end up there than water spray or cold air. The five-liter car is so packed that there's no room for anything else (not even the mechanic ).  |
Sternapotheke - no thank you!!
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
02-02-2010, 12:07 Subject: |
"...so, for us, a snowplow would be much more important right now... because even clear visibility only reveals roads that are often impassable, and in addition to large amounts of snow, more and more trees are falling." So, the trees that Kyrill spared at that time  .
goettmann Guest
02-02-2010, 15:00 Subject: |
Sternapotheke - no thank you !!
That was a great start for the first post on the forum!
