Used Passat 3C Key Programming (2010)
PAOKGREEK
Post18-02-2010, 9:58    Subject: Used Passat 3C Key Programming (2010) Quote
Hello, unfortunately, I haven't found anything suitable here related to that topic.
We lost our second key for a Passat 3C BlueTDI, manufactured in May 2010, in Switzerland.
A new key costs approximately 140 euros, plus 40 euros for programming.
I read on Google that supposedly only the radio control can be programmed, even with VCDS.
However, the immobilizer function can only be activated by the dealer using the login code.
However, since used ones are available for 50 euros on eBay, the thought of buying one there comes to mind.
It won't work like that because the immobilizer can only be programmed once on the key.
Is this correct?
Can the transponder be replaced?
So, are we going to be nice and bite into the sour apple?
Translated on 29-09-2026, 0:59.
Post18-02-2010, 10:05    Subject: Used Passat 3C Key Programming (2010) Translating...
[Translating...]
http://www.passatforum.com/forum/viewtopic.php?f=30&t=22464
PAOKGREEK
Post18-02-2010, 10:23    Subject: Used Passat 3C Key Programming (2010) Quote
So, no.
Thank you very much icon_biggrin.gif.
Translated on 29-09-2026, 1:00.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Used Porsche Mileage: What to Look For General Tips
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
No new posts Passat 3C Remote Key Fob Programming - Old Key On-Board Diagnostics (OBD)
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
