teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
17-02-2010, 21:14 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
After checking the glow plug system, I now need to replace the ignition coil.
Is it better to completely remove the entire air filter housing to access the intake manifold from the right side for tightening?
Using a ratchet wrench with a double-offset of either 3/8 or 1/4 inch, pass it through the bridge.
or should the intake manifold be completely removed to access it?
Has anyone ever done this before, and do you have any tips? Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 01-10-2026, 6:15.
Profile PM Email Garage |
17-02-2010, 22:02 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
Are there no MB people here?  Gruß, der Teileklaus
Translated on 01-10-2026, 6:16.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
17-02-2010, 23:15 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
Sure, dear TK!
Disassembling is often faster than struggling with it! Then you can easily access the spark plugs, and you can hold the ignition coil connector in place while loosening the spark plugs. Everything else is just unnecessary fiddling that wastes time. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
18-02-2010, 10:38 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
Hello Klausi
If you have the MB special tool to remove the crankshaft pulley, specifically that long socket with the tight cross joint and clamp inside, then you can skip removing the fan belt.
I would only remove the grounding bridge if the ESD devices are also being replaced.
If you only have a simple cross joint on the ratchet and it's wobbling around, I would remove the air filter, because otherwise certain spark plugs will drive you crazy. But even with the air filter removed, it's still a challenging job.
Translated on 01-10-2026, 6:17.
Profile PM Garage |
18-02-2010, 15:03 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
Thank you, I'll go ahead and put my knee joint in the rain so it becomes more difficult to move  . Gruß, der Teileklaus
Translated on 01-10-2026, 6:18.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
18-02-2010, 16:48 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
Or maybe stick a little bit of isolation tape around it...  2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Profile PM Garage |
18-02-2010, 18:28 Subject: Mercedes 124 Glow Plugs Replacement (1990) |
I know, it was a Joki  . Gruß, der Teileklaus
Translated on 01-10-2026, 6:19.
