Marko Blaumann
Joined: 04/15/2002 Posts: 136 Karma: +1 / -0 Location: Rennersdorf
20-05-2003, 13:11 Subject: Wheel Bearing Problems? Diagnose and Repair. |
Hi!
I've recently been experiencing a knocking sound coming from the rear axle on the right side, and it just won't go away.
The wheel bearings are in good condition, have been tightened, and are not running hot.
The tires are also in good condition and have been swapped to the front.
The funny thing is, when I turn right, it disappears.
Any ideas?
cu: Marko Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 28-10-2026, 11:14.
Gremlin Guest
20-05-2003, 16:51 Subject: Wheel Bearing Problem? Diagnose and Repair. |
Any ideas?
I was recently a passenger in an Opel Astra, and I would have bet 100 euros that either a shock absorber or a wheel bearing was broken.
Good thing I didn't bet on it, it was just the exhaust system that was falling apart. It got stuck in such a way against the axle that all the vibrations were being transferred to the body.
Check if all the rubber straps are still intact.
CU Gremlin.
Translated on 28-10-2026, 11:15.
Marko Blaumann
20-05-2003, 17:07 Subject: Wheel Bearing Problems? Diagnose and Repair. |
Hi Gremlin!
Hey, there's no exhaust system here.
It sounds exactly like a faulty wheel bearing, but it's not.
It starts at 80 km/h, becomes extremely loud at 100 km/h to the point where it's almost impossible to have a conversation, and disappears again at 130 km/h.
Like a kind of imbalance.
Translated on 28-10-2026, 11:17.
kenny Guest
20-05-2003, 17:26 Subject: Wheel Bearing Problems? Diagnose and Repair. |
I once had something similar with an old BMW. It was the tires, and the metal insert inside had been worn through.
It was incredibly dangerous; a small stone at 180 km/h could have caused a flat tire.
Translated on 28-10-2026, 11:18.
Markus H. Guest
20-05-2003, 21:07 Subject: Wheel Bearing Problems? Diagnose and Repair. |
There's quite a bit of evidence supporting Kenny's theory, as the rear tires on the C4 can last incredibly long – at least in terms of tread depth – while you simply can't keep up with replacing the front tires.
Marko Blaumann
21-05-2003, 8:53 Subject: Wheel Bearing Problems? Diagnose and Repair. |
HI!
Alle 4? Nice shit.
@ Markus
I can only agree with you on that  .
I still remember my "tire-eating" statement.
The sound appeared out of nowhere, one second and then the next.
Translated on 28-10-2026, 11:19.
Gremlin Guest
22-05-2003, 19:26 Subject: Wheel Bearing Problems? Diagnose and Repair. |
Look HERE .
and HERE (image search: what is missing here?)
CU Gremlin.
Translated on 28-10-2026, 11:20.
Marko Blaumann
23-05-2003, 17:23 Subject: Wheel Bearing Problems? Diagnose and Repair. |
AUAAA, but it probably drives well  . Lieber TDI statt lahme Ente!
Gremlin Guest
23-05-2003, 17:27 Subject: Wheel Bearing Problems? Diagnose and Repair. |
The vehicle was NOT here for that reason.
This only became apparent under those specific conditions. The plan was for regular service.
According to the customer's own statement, they didn't notice anything  .
Cu Gremlin.
