Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L
schliwi356
Post21-02-2010, 0:53    Subject: Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L Quote
Hello everyone.
I have a 1999 VW Lupo 3L, and I would like to properly adjust the clutch engagement point and the gear shifting.
Warum?
In einem VW Betrieb wurde für EUR 150 eine Getriebeeinstellung vorgenommen, weil die Schaltung nicht mehr in der Lage war im STOP Bereich den Motor abzustellen/starten. Sie haben mir empfohlen den Gangsteller zu ersetzten. Ich habe einen gebrauchten Gangsteller sowie die komplette Hydraulikeinheit ausgetauscht, jedoch wurde zwar dieses Problem behoben aber wieder neue eröffnet. icon_confused.gif
Problem
The circuit is so imprecise that the gears are not engaging correctly. The car is not drivable. The engine starts just (5mm) before neutral. The shift gate does not correspond to the transmission. The engine jerks and the transmission makes noises.
Procedure
Using a diagnostic tool, I repeatedly ran through the control program without seeing any improvement. The clutch engagement point was adjusted to 1.87V. A total of 28 switching cycles were performed.
Question
How can I precisely adjust the linkage? I tried adjusting it using the nut on the linkage rod at the bottom of the gearbox, but I'm not sure exactly how to proceed.
Does anyone here have experience or a detailed guide on this topic?
Translated on 12-07-2026, 8:12.
Post21-02-2010, 10:54    Subject: Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L Quote
Eine schön klar gegliederte Anfrage. Keep it up.
Right off the bat: I'm completely unfamiliar with this transmission and I only quickly compared your information with some repair manuals. To me, it sounds like you might have a more fundamental problem.
Therefore, my questions are:
What spare parts were installed?
a) Are you sure those are the correct parts? According to the repair manuals, there are different versions (e.g., "stop" positioned at the top or top left), and the change occurred around the end of the 2000s. There might be compatibility issues, and it's possible that you installed the wrong part.
b) Are the used parts guaranteed to be in working order?
PS: For a more detailed guide, an email address would have been helpful icon_wink.gif.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 12-07-2026, 8:15.
schliwi356
Post21-02-2010, 12:06    Subject: Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L Quote
Hello Guste,
The gear selector on the transmission was replaced, including the complete hydraulic unit.
Regarding your question: You are correct that there are two different versions of the shift linkage, however, this is the correct replacement part and was 100% functional. The donor Lupo from '99 also had only just under 60,000 km on the odometer.
I think it's more likely a calibration issue, because I'm not entirely sure how to properly adjust this kind of circuit. Now, even when the motor is supposed to be stopped, it still runs, which it didn't do with the old system. And if you can start it just before the "N" position, then the circuit must be misadjusted...
Sorry! My email address is "ivi _at_ freesurf.ch".
Schliwi.
Edit: Email address edited to prevent spam.
Translated on 12-07-2026, 8:17.
bakkano
Post21-02-2010, 12:22    Subject: Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L Quote
In which selector lever position did you make the adjustment?
We recently made the same adjustment on an A2 with a similar transmission.
If I remember correctly, the lever needs to be in position "D".
Translated on 12-07-2026, 8:19.
schliwi356
Post21-02-2010, 12:33    Subject: Clutch engagement point and gear shift adjustment for Volkswagen Lupo 3L Quote
Hello bakkano.
Vielen Dank für deine Antwort. Das Schaltprozedere wird praktisch in allen Gängen durchgeführt inkl. Tiptronic Gasse. Das Programm schaltet selbständig 28 Gänge inkl. Rückwärtsgang durch. D
Da Can't you leave the lever in position "D" and tighten the nuts at the bottom? The connection isn't mechanical, but electro-hydraulic.
[Name]liwiYou can't leave the lever in position "D" and tighten the nuts at the bottom because the connection is not mechanical but electro-hydraulic.Regards,Okay, here's the translation:
"Schliwi"
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust settings Diesel Engine Technology
No new posts VAG Wiring Harness: Ulf's Guide On-Board Diagnostics (OBD)
No new posts 2.4GHz Circuit Clone: Layout and Design On-Board Diagnostics (OBD)
No new posts Very convoluted circuit Diesel Engine Technology
