Versorgung Lenkwinkelgeber G85: Zündung und Dauerplus? | Posts 16+
Go to page: Previous  1, 2
Post26-02-2010, 16:03    Subject: Quote
dieselmartin wrote:
Without the G85, the servo will also fail.
During operation, I would have naturally applied voltage to all the power lines.
Actually, it doesn't matter anymore: my G85 is only drawing about 1 µA through the constant power supply, and it's really not worth disconnecting it for that small amount of current.
Translated on 17-07-2026, 23:59.
No new posts Charging/maintaining the battery via the vehicle's perman... Diesel Engine Technology
No new posts Ignition: On/Off at Battery Ground Connection Diesel Engine Technology
No new posts A3: No Radio Power When Ignition Off? Transmission, Chassis, Body & Interior
No new posts V6 ABC Engine: VCDS Ignition Base Setup (1996) On-Board Diagnostics (OBD)
