bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
23-03-2010, 21:06 Subject: Driver's door won't open |
Hello everyone.
I'm having a problem with my Golf III. The driver's side door won't open, but the door lock pin is moving normally. However, the door cannot be opened from either the inside or the outside.
Initially, I suspected something was loose, but after removing the door panel, I realized everything was fine; all the rods were properly attached.
I'm quite desperate now and don't really know what to do. It seems like the "latch" isn't releasing the door anymore. Is there a way to remove the lock from the inside?
Thank you for your help. Golf III TDI AHU 402Tkm
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
23-03-2010, 21:31 Subject: Driver's door won't open |
Oh dear... it looks like the lock is broken. Before you start taking things apart, try hitting the door firmly (but not in the middle, to avoid denting it). Maybe, with a bit of luck, it will open. If it does, immediately remove the lock! Unfortunately, I don't know any criminal methods to pick the lock from the outside, and I don't think that would work anyway because of the broken lock.
Back then, I used small pneumatic tools to pry open the lock from the inside. I don't know what the layout is like in your case, but in my situation, the back door was the one that was used.
Thumbs up, hope you can do it. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
bindpe Blaumann
23-03-2010, 21:56 Subject: Driver's door won't open |
hello
Thanks for the tip. The door panel is already off. I've already been fiddling with the door like an idiot, but I haven't tried hitting it yet. I'll give that a try tomorrow. It looks like I need to somehow pry the lock out from the inside. "So, you definitely can't get in there with large tools, I'm really at a loss." Golf III TDI AHU 402Tkm
23-03-2010, 23:31 Subject: Driver's door won't open |
bindpe wrote: | So, you definitely can't get in there with large tools, I'm really at a loss...
Pneumatic hoses, pneumatic saws, etc. are quite small. I can't think of any other small tools right now.
Sometimes, you can try gently tapping the lock from the inside with a small hammer. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
bindpe Blaumann
24-03-2010, 20:12 Subject: Driver's door won't open |
The idea with the hammer and a screwdriver was a good one  .
The door is open again, but unfortunately, the lock is broken.
"Thank you anyway!!!" Golf III TDI AHU 402Tkm
24-03-2010, 20:47 Subject: Driver's door won't open |
Great! Thank you for the feedback!  NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
