Hello Fabian,
Quote: |
| Is it possible to retrofit the EGT (Exhaust Gas Temperature) sensor using genuine VAG parts in such a way that the data is available in the engine control unit (ECU), specifically the EDC15P in my case |
No, it's simply because there's most likely no EDC15 control unit for your engine that includes exhaust gas temperature measurement.
So, there will be no software for it, and the hardware is not prepared for it either.
The only thing that comes to mind is to use an external exhaust gas temperature sensor system that simulates, for example, the oil temperature as an output voltage, and then have this value processed by a modified engine control unit.
