VP37 prüfen | Posts 16+
Go to page: Previous  1, 2
Post16-04-2010, 10:44    Subject: Quote
[Assumption] The used pump was purchased online and, unfortunately, is completely clogged with oil or a similar substance. [Assumption based on]
As mentioned before, try to absorb any spilled fuel with absorbent material ("leieren" in this context likely refers to using absorbent material).
Once the fuel starts flowing back through the return line, the fuel injector lines need to be bled to remove any trapped air.
My original pump: 028 130 109L.
The "new" pump: 028 130 110H
Look here:
http://www.bosch-automotive.com/ecat-online
Translated on 09-07-2026, 12:07.
kaindl
1994 Audi 80
Post16-04-2010, 11:02    Subject: Quote
Part 1 of the assumption is completely correct, but I can only guess about part 2 icon_wink.gif.
I've already run the reverse cycle, but the pump couldn't generate enough suction or achieve a higher speed to actually pump anything.
I know that the pumps aren't exactly the same. However, I found someone on Mecki's forum who has the same pump in their B4 and provided me with the pinout diagram for the connector so I can rewire it. The only difference seems to be the connector.
I'm going to contact the seller now; the pump was advertised as being "fully functional."
Thank you for your help!!
Best regards, Kaindl.
Translated on 09-07-2026, 12:09.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Check two-mass flywheel. Upload
No new posts Check mileage: How to verify car mileage Transmission, Chassis, Body & Interior
No new posts VTG Adjustment: Check and Calibration Diesel Engine Technology
No new posts How to Test Voltage Regulators Diesel Engine Technology
