ESP Failure: Why It Activates Unnecessarily?
schrauber2904
Post25-11-2009, 8:56    Subject: ESP Failure: Why It Activates Unnecessarily? Quote
"Hi, my friend has a Passat with a 3B engine, and the ESP system starts to engage unnecessarily even in gentle curves. I've already checked the wheel speed sensors in the brake electronics diagnostic block to see if any of them are giving incorrect readings (e.g., due to damaged rotors), but I haven't found anything. I suspect it might be the lateral acceleration sensor. Interestingly, the problem only occurs when using winter tires. I had the thought that it might be related to the tires, but I can't quite imagine that being the cause."
Now, my question is:
What else could it be, and how can I test this component?
Translated on 16-10-2026, 4:36.
mserge
Post25-11-2009, 9:35    Subject: ESP Failure: Why It Activates Unnecessarily? Quote
Check the age of the tires and the tire pressure. If they are old (more than 5-6 years), you should replace them. If it works with the summer tires, then it's likely the lateral acceleration sensor that's triggering, but I don't think it's broken. Are the wheels that are currently mounted approved for this car and in good condition?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 16-10-2026, 4:37.
Post25-11-2009, 9:42    Subject: ESP Failure: Why It Activates Without Reason Quote
schrauber2904 wrote:
Hello, my acquaintance has a 3B Passat where the ESP starts to engage in slight curves. I have already observed the wheel speeds in the measurement block of the brake electronics to see if a sensor is possibly providing incorrect values (e.g., due to broken rotors), but nothing can be detected. I think it might be the lateral acceleration sensor. Strangely, the problem only occurs with winter tires. There was also the thought that it might be related to the winter tires. However, I can't really imagine that.
Do all four wheels have exactly the same size?
Possibly very different or extreme.
Is it possible to replace a single tire with a new one?
Translated on 16-10-2026, 4:38.
Post25-11-2009, 11:51    Subject: ESP Failure: Why It Activates Unnecessarily? Quote
If it has nothing to do with age, unless they have absolutely no liability anymore. I'm sure Rogers' approach will lead to success.
Translated on 16-10-2026, 4:40.
schrauber2904
Post26-11-2009, 19:07    Subject: ESP Failure: Why It Activates Unnecessarily? Quote
I'm also suspecting the tires. I need to see if I can borrow a set of winter tires from a friend to try out. I'll let you know if it works out.
schrauber2904
Post16-04-2010, 20:43    Subject: ESP Failure: Why It Activates Unnecessarily? Quote
After a long time, I wanted to provide some feedback on this issue. It turned out that the problem was with the wheelset bearings, which were causing the ESP (Electronic Stability Program) to activate.
I'm just surprised that these weren't replaced along with the front axle, especially since the control arms were replaced not long ago.
Okay, it doesn't matter now. new_all_coholic.gif The error has been fixed.
Translated on 16-10-2026, 4:41.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Consumption Spike? Peugeot HDI Troubleshooting Diesel Engine Technology
No new posts V6 BDG Compression Issues: Why It Happens? Diesel Engine Technology
No new posts Last reason to read alarm system: How? On-Board Diagnostics (OBD)
No new posts AGR Valve T5 2.5 TDI BPC - Not Working? Diesel Engine Technology
