Adjustment device for brake force regulator, Audi 80 B4
Post15-04-2010, 8:43    Subject: Adjustment device for brake force regulator, Audi 80 B4 Quote
Audi specifies adjustment device 3284 for the rear axle brake force distribution system when it is being deactivated. Basically, it's a plate with two bolts that are inserted into two holes on the brake force regulator for adjustment.
The tool is easy to make if you know the distance and diameter of the bolts. Measuring the distance at the built-in regulator is somewhat inaccurate, and it assumes the original condition.
Perhaps one of you has the dimensions (and bolt diameters), or can measure them from an existing 3284?
Thank you very much in advance!
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
wolfi_b
Post19-04-2010, 6:58    Subject: Adjustment device for brake force regulator, Audi 80 B4 Quote
I also built a replica of that thing.
[img][/img]
Pin pitch (center-to-center): 50mm; Pin diameter: 5mm.http://img64.exs.cx/img64/2637/lehre32842tw.jpg{MARKER}
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Post19-04-2010, 7:04    Subject: Adjustment device for brake force regulator, Audi 80 B4 Quote
Thank you! That's exactly what I wanted.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts ALB Adjustment: VW T4 Brake Force Limiter Calibration Transmission, Chassis, Body & Interior
No new posts Brake Force Limiter (Seat Ibiza 6K) Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi A6 3.0 TDI ASB: Specs & Info Diesel Engine Technology
