As you know, my tour transmission was "blessed" with a missing tooth on the shifting gear.
I couldn't find the broken piece in the oil, even though I looked thoroughly.
This is a latent issue, and it's somewhat concerning to me. Other parts haven't been affected. Nevertheless, I replaced the rear derailleur's 6th gear sprocket because it was required, and the old one, despite looking identical, was getting very hot and making noises after just one minute of unloaded running on the stand. Something must have changed in the toothing module/fit!
However, it also says "can be used together." I tried to see if I could save some.
In the case of the above-mentioned transmission, that is probably not the case.
Okay, for 1500 and with a warranty, I understand the decision.
"Even though I could have fixed it. It's probably just the bearings, possibly the synchronizing rings, and the broken wheel with its shaft. 1.5 liters of oil and sealant are needed. It also requires some brainpower and carefulness."
If you let someone else do it, you no longer have a choice. Moreover, the workshop was hesitant to take on the risk.
What has become of the profession of automotive mechanic...exchanging entire assemblies.
ed. @ Gertriebebauer: see "What is the cost of a touring transmission?"
As long as workshops are unable to install all the seals, even though the new sealant on the transmission separation joint proves that it was previously disassembled, I can understand why service advisors might prefer to use Aftermarket (AT) parts instead...
On the other hand, mistakes happen everywhere, even when entire things are being replaced or renewed.
Then, of course, the driveshaft came loose while I was on vacation.
"I'm experiencing an issue after replacing the clutch on a VAG vehicle."
