DPF Ausbauen oder Reinigen | Posts 16+
Go to page: Previous  1, 2
Benni
Post26-02-2010, 19:42    Subject: Quote
I've already shared some of my experiences (regarding the old system).
Does anyone have any information about the catalytic converter (KAT), or more specifically, to what extent the coating of the DPF contributes to the burning-off process?
The coating will inevitably wear down, and some material will likely be flushed out during the backwash process. The question then becomes whether the catalytic converter will still function properly, and whether its passive regeneration process will lose effectiveness.
But generally speaking, I think you can only lose if you immediately install a new one without even trying to flush it.
I'm excited icon_wink.gif.
Mine is approaching its third cycle. There are still 33,000 km to go.
Translated on 10-09-2026, 15:54.
dieselheinz
Post10-05-2010, 14:26    Subject: DPF Removal vs. Cleaning: Which is Best? Quote
Hello.
I've been following this discussion for a while, and I've also been thinking about cleaning my filter.
I still have a few questions about it.
My Passat (BMR) has now reached 170,000 km and has an ash content of 53, so a cleaning process would definitely be beneficial.
What's the best way to proceed? Should I use a high-pressure washer to flush it out, or just rinse it with a stream of water from the tap?
Is it more efficient to flush in the direction of the exhaust flow or against it?
Is there a guide anywhere online that shows how to remove the filter, and what's the best way to do it?
I hope someone here has some answers.
Translated on 10-09-2026, 15:56.
Back to top Profile PM Email
Post10-05-2010, 17:08    Subject: Quote
Of course, you have to flush it in the opposite direction, otherwise very little will come out.
Translated on 10-09-2026, 15:57.
Benni
Post10-05-2010, 17:43    Subject: Quote
I wouldn't use a pressure washer either, as the jet could be too strong.
I took a garden hose and made a plug using rags and tape. While running water through it, I vigorously shook the DPF. (It gave me a good muscle ache).
Unfortunately, I can't help with the expansion work; I had the workshop do that as part of the ZR replacement.
Thale is actually a nice area, and I occasionally go there on weekends icon_smile.gif.
Translated on 10-09-2026, 15:58.
dieselheinz
Post10-05-2010, 18:51    Subject: DPF Removal vs. Cleaning: Which is Best? Quote
Okay, thanks for the information. I actually wanted to start working on it this week, but it's supposed to rain all week, and since I always work in the garden and there's no roof, I'll probably have to postpone the project for a bit.
Does it produce a lot of visible ash?
I also occasionally go to Braunschweig, where my sister lives.
Best regards from Thale.
Translated on 10-09-2026, 15:59.
Benni
Hutfahrer likes this.
Post10-05-2010, 23:05    Subject: Quote
In my case, it was visibly noticeable, but my filter is only at 150g of capacity, as I still have the additive system installed.
They were small, red/pink pieces.
The channels are quite narrow, and when you shake it, a lot of material comes out. That's why it takes a while.
Translated on 10-09-2026, 16:00.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Cleaner: Bosch vs. Pierburg - Which is Best? Diesel Engine Technology
No new posts LMM Cleaning: The Problem and Solution Diesel Engine Technology
No new posts Intake Manifold Deposits: Cleaning Guide Diesel Engine Technology
No new posts VTG (ALH) Cleaning: Get Help & Tips Now! Diesel Engine Technology
