I can't seem to make any progress with my problem on my own anymore.
Vehicle:
Passat 3B, manufactured in January 1999, 1.9L TDI, 66kW, engine code AHH.
Problem:
The fault memory indicates a difference in pressure in the turbocharger pressure control system.
When accelerating rapidly, the engine enters a limp mode at approximately 3800 RPM.
The actual boost pressure is too high!
After the engine is switched off, it continues to operate in its normal characteristic map until...
Incidentally, all this drama started after a visit to the technical inspection service (TÜV).
Previous measures:
The vacuum hoses in the system were inspected and/or replaced.
The turbocharger wastegate valve was defective and has been replaced.
After that, the car ran for approximately 5000 km without any problems until the familiar issue reappeared.
VTG rods are common and typically move about 1 cm.
I'm completely at a loss!
I have uploaded a log file to the "Upload" section.
/viewtopic.php?p=168449#168449
I would really appreciate it if one of the "Diesel Foxes" could take a look at the file and give me a general direction for further troubleshooting.
Thank you very much!
Greetings from Franconia.
Christoph.
