Engine Control Unit Golf IV TDI ALH
jannik
Post01-08-2005, 18:59    Subject: Engine Control Unit Golf IV TDI ALH Quote
Hello everyone.
I would like to install a new engine control unit (ECU) in my Volkswagen Golf IV.
Volkswagen Golf, manufactured in 1999, with a TDI engine (engine code: ALH).
I've already gotten another one (with the same Bosch and VW part numbers).
I also have VAGCOM.
Could you please provide me with instructions on how to code the engine control unit (ECU) using VCDS?
"Thank you."
Translated on 16-08-2026, 5:39.
Post01-08-2005, 20:32    Subject: Engine Control Unit Golf IV TDI ALH Quote
There's not much to consider, but you will need a VAG-COM device with the unlocked version.
Encoding: 1 represents an automatic transmission, and 2 represents a manual transmission.
To program the immobilizer: Access the combination instrument, read and save adaptation channel 0, turn off the ignition for 15 seconds, and you're done.
Translated on 16-08-2026, 5:40.
jannik
Post05-08-2005, 17:16    Subject: Engine Control Unit Golf IV TDI ALH Quote
I have another question about my engine control unit (ECU).
Okay, I've acquired a used engine control unit (ECU), and now I'm going to install a chip into it.
Coding: 1 indicates an automatic transmission, and 2 indicates a manual transmission.
To pair the immobilizer: Go to the combination instrument, read and save adaptation channel 0, turn off the ignition for 15 seconds, and you're done.
Besides what is described above, are there any other things I need to consider in order to use both engine control units (the original one and the one with the chip)?
I want to be able to swap out the control units.
Thank you.
Translated on 16-08-2026, 5:42.
Post05-08-2005, 17:25    Subject: Engine Control Unit Golf IV TDI ALH Quote
No, otherwise there's nothing else to note.
Translated on 16-08-2026, 5:43.
oliverzier
Post14-06-2010, 10:12    Subject: Engine Control Unit Golf IV TDI ALH Quote
Hi, I'm also changing the MSG at my place tonight.
Do you need the logic code for the AI?
Post14-06-2010, 12:17    Subject: Engine Control Unit Golf IV TDI ALH Quote
oliverzier wrote:
Do you need the source code for the AI?
Yes.
Translated on 16-08-2026, 5:44.
Post14-06-2010, 13:44    Subject: Engine Control Unit Golf IV TDI ALH Quote
TDI-GTI-4-Motion wrote:
Yes.
Sure? Not with WFS-II.
Post14-06-2010, 15:47    Subject: Engine Control Unit Golf IV TDI ALH Quote
Rainer K. wrote:
Are you sure? It's not the case with WFS-II.
It's not the case with IMMO II. I just checked and it's an IMMO III system, but since the car is from 1999, it still has IMMO II installed. Sorry for the mistake.
Translated on 16-08-2026, 5:45.
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error Golf 4 TDI: Engine Control Unit Problem On-Board Diagnostics (OBD)
No new posts Golf 4 ECU Coding: How-To Guide On-Board Diagnostics (OBD)
No new posts Engine control unit locked, Golf 2 TDI AFN On-Board Diagnostics (OBD)
No new posts Golf 4 engine control unit programming On-Board Diagnostics (OBD)
