Golf 3 TDI 90 hp, brakes? Stabi?
Stukov
Post03-06-2003, 20:16    Subject: Golf 3 TDI 90 hp, brakes? Stabi? Quote
I'm interested in knowing what was the minimum brake system size (13' or 14') that was originally installed in the 90 horsepower TDI engine in the Volkswagen Golf 3. And whether or not the stabilizer bar was installed on the front axle of all TDI models.
Thank you very much.
Stukov.
Varianti
Post04-06-2003, 7:10    Subject: Golf 3 TDI 90 hp, brakes? Stabi? Quote
13-inch rims for a Golf TDI? I haven't heard of that before, and it wasn't listed in the vehicle registration document.
The stabilizer is also available for the 90 horsepower model.
Stukov
Post04-06-2003, 7:39    Subject: Golf 3 TDI 90 hp, brakes? Stabi? Quote
Thanks, as far as I've found out so far, the 90 hp TDI only comes with a brake system that's at least 14 inches in size. However, it seems to be a solid brake system, so I think the question is probably answered.
Does anyone know if the stabilizer bar was installed in EVERY 90 hp TDI model? Sure, here's the translation:
'So, for example, also in the CL version?'
Vasmodis
Post05-06-2003, 18:55    Subject: Golf 3 TDI 90 hp, brakes? Stabi? Quote
Hello!
13-inch wheels were only available with the 1Y (47 kW / D) and AAZ (55 kW / TD) engines.
For the 1.9-liter diesel CL/GL/GTD models, the front brake discs are 239 mm in diameter.
The 1.9 TDI engine has 256 mm brake discs at the front.
The 90 horsepower version comes with a stabilizer bar in the front, but not in the rear.
Vasmodis!
Stukov
Post05-06-2003, 23:22    Subject: Golf 3 TDI 90 hp, brakes? Stabi? Quote
Thank you!
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 4Motion Stabilizer Bar Transmission, Chassis, Body & Interior
No new posts H&R Anti-Roll Bar for VW Golf 4 4Motion: Does it work? Transmission, Chassis, Body & Interior
No new posts Brakes on the Golf 3 Transmission, Chassis, Body & Interior
No new posts Golf 3 Brakes: Adjustable BKV? Transmission, Chassis, Body & Interior
