GALA Signal in the Passat
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Werner
Post06-06-2003, 12:31    Subject: GALA Signal in the Passat Quote
I wanted to install my new Blaupunkt radio (previously beta) yesterday, and I noticed that the GALA signal is missing from pin 1. Does anyone know where in the electrical panel you can tap into it?
Furthermore, I am not sure whether my antenna is fed externally (I will probably need to measure it again today...).
Thank you, Werner
Passat Variant, AFN, Year 1998
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2303 - Ignition Coil B, Primary Circuit: Signal too low Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem mit GALA und NAVI-Durchsagen mit RNS-D im A4 8E Transmission, Chassis, Body & Interior
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Signal Verbrauchsmessung TDI 1Z Diesel Engine Technology
No new posts NOx signal too low Diesel Engine Technology
