Polo 99 (6N1) WFS PIN auslesen | Posts 16+
Go to page: Previous  1, 2
mullemaus
Post19-05-2010, 10:48    Subject: Quote
Testing, I'm not familiar with this tool. Therefore, I can't say whether it works icon_wink.gif.
Translated on 16-07-2026, 2:57.
alfstingray
Post30-07-2010, 11:54    Subject: Quote
Hello everyone,
The post is quite a few months old.
Now I'm having the same problem with an immobilizer from a Caddy 9K 1.9 SDi.
He probably installed the same WFS module (Volkswagen part number 6HO 953 257B, Siemens part number 5WK4 7740).
According to the photo, at least the interior looks the same.
My K+Can commander and the USB-based speedometer have failed.
k+Can initially didn't even recognize the WFS box.
"The Tacho USB device recognized the control unit but denied access when attempting to read the WFS pins."
I have tested the same device in three other cars, but I got the same result in each one.
Has a solution to this problem emerged yet?
Best regards.
Translated on 16-07-2026, 2:59.
mullemaus
Post30-07-2010, 13:11    Subject: Quote
If you use the special tool, you need a PROGRAMMED key. It is definitely possible to do it. Be sure to consider any potential lock-out times (which are not displayed!!). So just leave the ignition on for 30 minutes. icon_wink.gif
Translated on 16-07-2026, 3:00.
alfstingray
Post30-07-2010, 14:14    Subject: Quote
mullemaus wrote:
Wenn Du das Spezialtool nutzt, brauchst Du einen ANGELERNTEN Schlüssel. Es geht defintiv zu machen. Gegebenfalls Sperrzeiten beachten (werden nicht angezeigt!!) Also mal einfach 30min mit Zündung an stehenlassen. icon_wink.gif
Thank you very much for the quick response.
Here we go again, my next problem.
I don't have a master key. The customer has lost all of them.
The friendly person also tried it before me and gave up.
Is there a way to directly read data from the chip?
Translated on 16-07-2026, 3:01.
mullemaus
Post30-07-2010, 14:54    Subject: Quote
Gibt es eine Möglichkeit direkt vom Chip die Daten auszulesen?
Without a key, it won't work with any tool. It's not possible to directly read data icon_wink.gif.
Translated on 16-07-2026, 3:02.
alfstingray
Post30-07-2010, 15:38    Subject: Quote
What do I need to directly read data from a chip?
I would appreciate a little help getting started.
Or, what would it cost to have it done?
mullemaus
Post31-07-2010, 19:17    Subject: Quote
What do I need to read data directly from the chip?
Bzw. was würde es kosten es machen zu lassen.
Special hardware and software. icon_cool.gif You need to ask the respective providers about the price. icon_wink.gif
Translated on 16-07-2026, 3:03.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 97 Polo MKB AEE, Diagnostic error reading Gasoline Engine Technology
No new posts Polo 2F 3F Engine: Read/Log Lambda Values On-Board Diagnostics (OBD)
No new posts How to Read: A Beginner's Guide On-Board Diagnostics (OBD)
No new posts Read Email: Extracting Messages Easily On-Board Diagnostics (OBD)
