Kompressionsmessung am VW/Audi 3.0 V6 TDI | Posts 16+
Go to page: Previous  1, 2
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post05-08-2010, 21:44    Subject: Quote
Hello everyone.
If there is one or more holes in the piston, a significant amount of fresh air/exhaust gases should enter the crankcase through these holes.
When opening the oil filler cap, you should definitely feel or hear something – it should release with some pressure.
It would be at least one way to find out more about the pistons without having to disassemble everything.
When you remove the fuel lines from the injectors and the fuel rail, the valve covers can be easily and quickly removed. This allows you to relatively easily rule out mechanical problems with the valve actuation system. However, this doesn't mean you can see whether the valves are sealing properly.
Mfg Mpire
Translated on 31-08-2026, 10:43.
Frank F.
Post06-08-2010, 8:36    Subject: Quote
Hello everyone!
Okay, great! Then I'll take off the oil cap, let's see if it whistles icon_smile.gif.
Best regards!
Frank.
Translated on 31-08-2026, 10:44.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Kompressionsmessung unplausibel Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts LOG Audi 2.5 AKE Upload
