Golf V: Heater Not Working? Troubleshooting
chriskross
Post06-08-2010, 16:09    Subject: Golf V: Heater Not Working? Troubleshooting Quote
Hello, I have a Volkswagen Golf V BRU 1.9 PD.
The problem is that the heating is now blowing cold air, and the thermostat has already been replaced.
The upper radiator hose is hot, while the lower one remains cold.
Kühlmitteltemperatur 90 Grad lt. Advertisement (fixed price)
Cooler outlet temperature, according to vcds, is 35 degrees Celsius during operation.
Idling: approximately 75 degrees.
I also disconnected the thin hose from the expansion tank, and a good amount of coolant came out. I think this allows me to rule out the water pump as the cause.
I would be grateful for any advice.
Best regards, Chris.
A6 AFB
A6 BRE DPF
Translated on 28-09-2026, 9:37.
Post06-08-2010, 16:13    Subject: Golf V Heater Not Working? Fix It Now! Quote
What are we talking about? The water cooler or the heat exchanger for the interior?
Have you ever checked the error memory of the heating/climate control system? It's possible that the servo motor for the temperature flap is defective, and the flap is stuck in the cooling position.
Translated on 28-09-2026, 9:39.
chriskross
Post06-08-2010, 16:18    Subject: Golf V: Heater Not Working? Troubleshooting Quote
Hi!
The hoses connecting the water cooler to the heat exchanger are hot.
A6 AFB
A6 BRE DPF
Post06-08-2010, 20:55    Subject: Golf V: Heater Not Working? Troubleshooting Quote
chriskross wrote:
..the hoses to the heat exchanger are hot
Then you know what's up. Either the actuator or the valve is defective.
Translated on 28-09-2026, 9:40.
chriskross
Post07-08-2010, 10:17    Subject: Golf V: Heater Not Working? Troubleshooting Quote
TDI-GTI-4-Motion wrote:
Then you know. The stepper motor or the valve is defective.
Okay, I will check that.
"But what I don't understand is, shouldn't the lower radiator hose also be hot?"
A6 AFB
A6 BRE DPF
Post07-08-2010, 11:22    Subject: Golf V: Heater Not Working? Troubleshooting Quote
chriskross wrote:
but what I don't understand is, shouldn't the lower radiator hose also be hot?
If the thermostat is open, yes, but if it hasn't yet reached the opening temperature, it will remain cold.
Translated on 28-09-2026, 9:41.
chriskross
Post13-08-2010, 12:06    Subject: Golf V: Heater Not Working? Troubleshooting Quote
Hi!
I just replaced the servo motor for the temperature flap (part number V68), but the error code is still the same as it was before.
What I observed with the servo motor is that when you set the Climatic control to cold, the motor moves to its lower limit, while when you set it to hot, it stops at the halfway point.
When I run the basic calibration, it goes from stop to stop.
The MWB 12 temperature control valve is only opening to approximately 120 degrees instead of the expected 250 degrees when it should be fully open.
A6 AFB
A6 BRE DPF
Translated on 28-09-2026, 9:42.
chriskross
dieselschrauber likes this.
Post14-08-2010, 12:49    Subject: Golf V: Heater Not Working? Troubleshooting Quote
Hi!
I finally found the error; it was the G191 exhaust temperature sensor that was providing a false signal of 80 degrees. icon_twisted.gif
It would also be helpful if there were a German label file available for the Climatic Golf V.
A6 AFB
A6 BRE DPF
Translated on 28-09-2026, 9:43.
No new posts Heated, auto-dimming side mirror malfunction General Tips
No new posts P1118 - Oxygen Sensor Heater Circuit Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 2 Heater Not Working? Troubleshooting Diesel Engine Technology
No new posts Air conditioning / heating in VW T5 and T6 Transmission, Chassis, Body & Interior
No new posts Glühzeitsteurung (und Heizung) beim ASZ Diesel Engine Technology
No new posts A4/B5 Heat Exchangers: No Heating Needed - Solution Diesel Engine Technology
