"I'm having a problem with my car. It keeps going into limp mode (no power) randomly, and the warning light comes on. I've already replaced the turbocharger pressure sensor, but I'm still having the same issue. It might be a broken wire. How can I check the wiring?"
Sunday, August 8, 2010, 3:38:40:09726
VCDS Version: DRV 908.2
Data as of: 20100327
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 72 77
Vehicle Identification Number: WAUZZZ4E17N005046
Mileage: 188,720 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
06-Passenger seat adjustment -- Status: OK.
07-Control panel/interface -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
1E-Media Player 2 -- Status: OK 0000
Immobilizer system -- Status: OK 0000
34-Level regulation -- Status: OK.
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
38-Tile electronics -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
Address 01: Engine Control Unit
Label file: None
Part number SW: 4E0 *** 402 G, HW: 4E0 907 401 D.
Part: 3.0L V6 TDI, part number G001AG, revision A020.
Revision: --H03--- Serial Number: AUX3Z0F6199238
Encoding: 0011973
Operating number: WSC 49930 141 181006
"One error found:"
000567 - Charge pressure sensor (G31): Signal too low.
P0237 - 001 - Upper limit exceeded - Warning light ON.
Environmental conditions:
Error status: 11100001
Error priority: 0
Error frequency: 1.
Mileage: 188,727 km
Time: 0.
Date: 2010.08.07
Time: 23:43:23
Speed: 0 RPM.
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 0.060 V
Voltage: 12.24 V
Pressure: 999.6 mbar
Temperature: 35.1°C
Readiness: 0 0 1 1 1
Address 02: Transmission Label file: DRV\09L-927-760.lbl
Part number SW: 4E1 910 156 Q, HW: 09L 927 156 A.
Part number: AG6 09L 3.0 TDI RdW 0020.
Revision: --H01--- Serial Number: 4193192
Encoding: 0000001
Operating number: WSC 02313 785 00200
No error codes found.
Address 03: Brake Electronics Label file: DRV\4E0-910-517.lbl
Part number SW: 4E0 910 517 B, HW: 4E0 614 517 BC.
Part: ESP 5.7 all-wheel drive, H46 0510.
Encoding: 0008357
Operating number: WSC 27278 000 00000
Address 05: Access/Start Routine. Label file: DRV\4E0-910-131.lbl.
Part number SW: 4E0 910 131, HW: 4E0 909 131 G.
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial Number: AUX3Z0F6199238
Encoding: 0263168
Operating number: WSC 02311 785 00200
Part number: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Front Seat Adjustment
Label file: None
Part number SW: 4E0 910 760 D, HW: 4E0 959 760 B.
Component: Seat Memory Module BFS H02 0010.
Revision: 00000000 Serial number: 5DS 008 795-03
Encoding: 4063328
Address 07: Control unit/display unit. Label file: DRV\4E0-910-7xx-07.lbl
Part number SW: 4E0 910 769 D, HW: 4E0 035 729.
Component: Interface box H43 5150.
Revision: 00000000 Serial Number: 343GS067581822
Encoding: 0000001
Part number: 4E0 910 611.
Component: E0380 Control panel H03 0040
Address 08: Climate Control Module. Label file: DRV\4E0-910-043.lbl.
Part number SW: 4E0 910 043 B, HW: 4E0 820 043 G.
Component: CLIMATE CONTROL UNIT 017 0450
Revision: 00000032 Serial number: 00000000101873
Encoding: 0002113
"One error found:"
01274 - Actuator for pressure relief valve (V71).
003 - mechanical fault.
Error status: 01100011
Error priority: 3
Error frequency: 14
Lost Count: 131
Mileage: 188,630 km
Time: 0.
Date: 2010.08.07
Time: 00:18:13
Voltage: 12.20 V
Temperature: 19.0°C
(no unit): 196.0
(no unit): 194.0
Temperature: 29.0°C
Address 09: Central Electronics
Label file: 4E0-910-279.lbl
Part number SW: 4E0 910 279 Q, HW: 4E0 907 279 Q.
Component: ILM Driver H15 0230
Encoding: 0043121
Part number: 4E1 910 113 B.
Component: Wiper blade WWS D3 H50 0400.
Encoding: 00000034
Part number: 4E0 910 557 B.
Component: RAIN SENSOR H13 0100
Encoding: 00141886
Address 15: Airbag
Label file: DRV\4E0-910-655-94.lbl
Part number SW: 4E0 910 655 D, HW: 4E0 959 655 H.
Part: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P000MB0P
Encoding: 0430707
Address 16: Steering wheel electronics
Label file: DRV\4E0-910-549.lbl
Part number SW: 4E0 910 549, HW: 4E0 953 549.
Component: Steering column module H14 0040.
Encoding: 0012041
Component: Steering wheel module H07 0090.
Address 17: Control panel module
Label file: DRV\4E0-910-xxx-17.lbl
Part number SW: 4E0 910 901 C, HW: 4E0 920 901 C.
Bauteil: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial Number: AUDID3F6001151
Encoding: 0000013
Operating number: WSC 00011 888 96745
Address 18: Auxiliary heater
Label file: DRV\4E0-910-105.lbl
Part number SW: 4E0 910 105 A, HW: 4E0 815 069 F.
Component: Heating device H07 0110
Revision: 0000000C Serial number: 00000009006406
Encoding: 0000001
Operating Number: WSC 00000 000 00000
Address 19: Diagnostic interface
Label file: DRV\4E0-910-468.lbl
Part number SW: 4E0 910 468 B, HW: 4E0 907 468 E.
Component: Gateway H11 0090
Revision: 11 Serial Number: 200030653000ED
Encoding: FCFE7BDE2B3104
Address 1E: Media Player 2
Label file: DRV\4E0-910-111.lbl
Part number SW: 4E0 910 111 F, HW: 4E0 035 111 A.
Component: CD Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8157992
Address 25: Immobilizer
Encoding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Label file: DRV\4E0-910-553.lbl
Part number SW: 4E0 910 553 H, HW: 4E0 907 553 F.
Component: AIR FILTER - CDC H06 4480
Coding: 0015510
Address 36: Seat adjustment for driver. Label file: None.
Component: Seat Memory FS H02 0010.
Encoding: 4063330
Address 37: Navigation
Label file: DRV\4E0-910-88x-37.lbl
Part number SW: 4E0 910 887 Q, HW: 4E0 919 887 D.
Component: MNS ECE H48 0850
Revision: 00000000 Serial Number: 364GW067578115
Address 38: Roof electronics Label file: DRV\4E0-910-135.lbl
Part number SW: 4E0 910 135 A, HW: 4E0 907 135 A.
Component: Roof connection D3, part number H05 0090.
Serial number: 00000618900036
Encoding: 0003092
Operating number: WSC 50954 141 89497
Address 42: Door Electric Driver
Label file: DRV\4E1-910-802.lbl
Part number SW: 4E1 910 802 B, HW: 4E1 959 801 B.
Component: Door control unit. FS BRM003 0100.
Encoding: 0028448
Address 46: Comfort System
Label file: 4E0-910-289.lbl
Part number SW: 4E0 910 289 D, HW: 4E0 907 289 D.
Component: Comfort Device H07 0010
Revision: 00100007 Serial Number: W040607200304
Encoding: 0000616
Part number: 4E0 910 853.
Part: Rear lid
P14H06 0070
Address 47: Soundsystem
Label file: 4E0-910-223.lbl
Part number SW: 4E0 910 223 J, HW: 4E0 035 223 D.
Component: Amplifier Base H41 0120
Revision: 00000000 Serial number: 00000067511226
Encoding: 0000002
Address 4F: Central Electricity II
Label file: DRV\4E0-910-280.lbl
Part number SW: 4E0 910 280 A, HW: 4E0 907 280 A.
Part: ILM Passenger Side H11 0070
Revision: Serial number: 00000000089712
Encoding: 0010101
Address 52: Door electric, passenger side.
Part number SW: 4E1 910 802 B, HW: 4E1 959 802 B.
Component: Door control unit. BF BRM003 0100
Encoding: 0028448
Address 53: Parking brake
Label file: DRV\4E0-910-801.lbl
Part number SW: 4E0 910 801 C, HW: 4E0 907 801 A.
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Encoding: 0000221
Operating number: WSC 27278 141 87622
Address 55: Headlight range control. Label file: DRV\8P0-907-357.lbl
Part number: 8P0 907 357 F
Component: Dynamic LWR, H02 0010.
Revision: 00000001 Serial number:
Encoding: 0000006
Address 56: Radio
Label file: DRV\4E0-910-541.lbl
Part number SW: 4E0 910 541 Q, HW: 4E0 035 541 P.
Part: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396G 067542719
Encoding: 0000001
Address 61: Battery Management
Label file: DRV\4E0-910-181.lbl
Part number SW: 4E0 910 181 C, HW: 4E0 915 181 C.
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000013489
Operating number: WSC 27669 141 67137
Part number: 4E0 915 105 A
Component: VA0 610402092
Encoding: 344530393135313035412056413036313034303230393220
Operating number: WSC 00011 888 06946
Address 62: Door electric strike, left and right.
Label file: DRV\4E0-910-802.lbl
Part number SW: 4E0 910 802 A, HW: 4E0 959 801 C.
Component: Door control unit. HL BRM003 0100
Encoding: 0028448
Address 72: Door electric strike, high, right.
Part number SW: 4E0 910 802 A, HW: 4E0 959 802 C.
Component: Door control unit. HR BRM003 0100.
Encoding: 0028448
Address 76: Parking Assist
Label file: DRV\4E0-910-283.lbl
Part number SW: 4E0 910 283 C, HW: 4E0 919 283 C.
Component: Parking Assist System, 8-Channel, Part Number H12 0040.
Revision: 00H12000 Serial Number: 08720619401666
Encoding: 0201008
Address 77: Telephone Label file: DRV\4E0-910-336.lbl
Part number SW: 4E0 910 336 L, HW: 4E0 862 335.
Component: Mobile phone part 2, H20 1120.
Revision: 00000000 Serial number: 00000005193714
Encoding: 0010910
End.
Translated on 10-10-2026, 3:04.
