4.0TDI ist ein Chip verbaut? | Posts 16+
Go to page: Previous  1, 2
liebst
Post19-08-2010, 22:05    Subject: Quote
Hello!
First of all, thank you very much, @rainerViewing profile: rainer, for your efforts!
The engine control units look unchanged, and there's nothing visible on the connectors to indicate that they were ever removed or modified. I also haven't found any evidence of a potentially installed "dummy" module.
After a complete error scan, the following error was displayed:
"Control unit for throttle valve: electrical fault."
P3243 - 002 - Lower limit exceeded."
Could this potentially lead to an increased fuel injection amount because the engine control unit (ECU) receives a false reading?
Regarding the offer "someone might come and take a look or dismantle it," since the vehicle is located in Austria, near Vienna, I believe it will be difficult for anyone here on the forum to simply drop by.
Translated on 01-09-2026, 4:44.
Post20-08-2010, 8:25    Subject: Quote
I think it's a good idea to purchase your own diagnostic tool. Your car has a lot of potential in that area, and if you plan to drive it for a long time, it will quickly pay for itself.
You also can't easily get SW updates here, maybe it's due to your "friend bonus." The update for the BPC required a lot of explanation, and getting to the TPL was even more difficult. My experience: if you tell them exactly what it is and what they should do, they become unfriendly, nervous, and stonewall you. You have to act clueless, describe the problem in a way that leads them to the TPL, and then motivate them to get started. 25 minutes is good, though; the bus was stuck for 2 hours while it was being fixed, and I had already tried all the coffee specialties from the free machine... and the customer restroom was a mess icon_sad.gif. Yes, some things you never forget icon_smile.gif.
Translated on 01-09-2026, 4:46.
Post20-08-2010, 9:27    Subject: Quote
Could this potentially lead to an increased fuel injection amount because the engine control unit (ECU) receives a false value or something like that?
No, the dataset is definitely manipulated.
Translated on 01-09-2026, 4:47.
Deus Violentia
Post20-08-2010, 11:44    Subject: Quote
Please provide the part number of the device!
Translated on 01-09-2026, 4:48.
liebst
Post20-08-2010, 12:02    Subject: Quote
Part number SW: 4E0 910 409 C, HW: 4E0 907 409 B.
Part number: 4.0L 4V/TDI A000AGMª0020
Revision: <> Serial Number: AUX3Z0C4116864
Encoding: 0010773
And what's the purpose of the part number?
Translated on 01-09-2026, 4:49.
Deus Violentia
Post20-08-2010, 14:03    Subject: Quote
I'd like to see if I can get an original file for that, and then you can get rid of the junk data in your control unit.
mullemaus
Post20-08-2010, 21:03    Subject: Quote
The software version is currently up-to-date. It's a new version, so an update is not possible. It needs to be installed using a tuning tool. icon_wink.gif
Translated on 01-09-2026, 4:50.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
No new posts ARL Chip Tuning: Improve Performance & MPG On-Board Diagnostics (OBD)
No new posts AWX and ASZ: What are the differences? When to install? Diesel Engine Technology
