The engine is very loud at RPMs above 3800.
Golfmann
Post15-06-2003, 19:58    Subject: The engine is very loud at RPMs above 3800. Quote
Hello everyone.
Yesterday, I noticed again that my car becomes very loud and rough when driving above 180 km/h.
I've tried it in other gears now and noticed that the engine doesn't quite run as smoothly above 3800 RPM.
Could it be related to the pump setting? I also have a slight [problem/issue]!! Starting problems.
I can't say for sure if I can reach my top speed, as I only have a speedometer that goes up to 200 km/h (1Z engine), and also the transmission from the 1Z. The speedometer is definitely showing a lower reading right now. That should be enough!
I converted my Golf 3 from a 1Z engine to an AFN engine. The engine now has approximately 60,000 km (37,000 miles) and there are no error codes. According to the display, the turbocharger pressure is also correct.
Ralf
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Fan constantly running at level 2 and very loud. Normal? Diesel Engine Technology
No new posts Vibration&Poltern sehr laut ist aber nicht Auspuff! Diesel Engine Technology
No new posts Golf IV ALH wird mit 0,205er Düsen aus ASV laut !!! Diesel Engine Technology
No new posts Volvo V70: Loud Engine Knocking - What to Do? Diesel Engine Technology
