Passat TDI Starting Issues: 1Z Engine Troubleshooting
Post04-09-2010, 10:53    Subject: Passat TDI Starting Issues: 1Z Engine Troubleshooting Quote
Hi.
It's about a car that belongs to a friend, but unfortunately, it's not located here with me.
Passat Variant 35i TDI with a 90hp 1Z engine from 1995, mileage >350,000 km.
The car starts briefly, revs up to just under 2500 RPM without any throttle input, and then immediately shuts off. The WFS (presumably a diagnostic system) shows no error codes, but the issue is flagged in the MSG (presumably a control module).
"Control unit defective" doesn't reappear after being cleared.
Where could we start here?
Best regards, Rüdi.
Translated on 28-08-2026, 20:09.
kossmann
2016 Audi Q3
Post14-09-2010, 8:13    Subject: Passat TDI Starting Issues: 1Z Engine Troubleshooting Quote
Was happened to the ESP? I remember that this could be a potential issue if the ESP is removed and not reinstalled exactly in the same position.
Translated on 28-08-2026, 20:10.
Post14-09-2010, 10:30    Subject: Passat TDI Starting Issues: 1Z Engine Troubleshooting Quote
Unfortunately, I don't have a good idea either, aside from Kossmann's ESP theory.
The "MSG defekt" error doesn't quite fit with that. A side question: Was the reading done with a current VCDS version? Older versions from "other sources" sometimes provide error messages that don't match the error code icon_wink.gif.
If needed: I have a working ESP (Electronic Stability Program) module from an AHU engine (the 1Z successor) that I want to sell (my Golf has been sold a long time ago, so I want to get rid of the spare parts). If needed: Please send me a private message or email to my username at GMX.de.
Greetings.
Guste.
Translated on 28-08-2026, 20:11.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2.0 TDI: Won't Start - Troubleshooting Diesel Engine Technology
No new posts Passat 1.9 TDI: Hard Starting Problems & Fixes Diesel Engine Technology
This topic is locked, you cannot edit or reply. Passat TDI: Starting Problems - Troubleshooting Guide Diesel Engine Technology
No new posts Passat 3B AHU won't start Diesel Engine Technology
