Katastrophe: neue Stelle für Kühlwasserverlust entdeckt | Posts 16+
Go to page: Previous  1, 2
haehnlein
Post14-06-2003, 21:17    Subject: Quote
Wurstblinker wrote:
Why is yours working better after the belt replacement?
ZKD replacement icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif I am convinced that a change with this LL will improve compression. Also, I cleaned the MAF sensor with brake cleaner icon_wink.gif.
____________
Kein Auto mehr!
Translated on 18-08-2026, 1:10.
Lucas
Post15-06-2003, 9:52    Subject: Quote
Hello!
Great, Christian, that you're sharing your experiences here... I also have my final exam coming up soon. This helps me know what else I need to pay attention to.
For your information: I also have the first 1Z engine in an Audi 80 B4 with 355,000 km, a top speed of approximately 185 km/h (according to the speedometer), and a fuel consumption of around 6 liters, mostly using biodiesel. The injectors, turbocharger, cylinder head, and fuel pump are all still original. I can confirm the issue with the 'rice-loving' ribbed belt.
'Question for owners of the older 1Z models: Does any of you have a VAGCOM adapter that works? I built one using a MAX232 chip, and it works with other newer vehicles, but unfortunately not with mine.'
Greetings.
Lucas.
Translated on 18-08-2026, 1:12.
Wurstblinker
Post15-06-2003, 12:29    Subject: Quote
Is the car compatible with biodiesel?
I always thought he wasn't ready for that yet!
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 18-08-2026, 1:14.
Post15-06-2003, 14:21    Subject: Quote
"Hi,"
According to VAG, starting with models from MJ96, the TDIs are suitable for use with Biodiesel. Have fun dealing with leaky pumps icon_smile.gif.
haehnlein
Post15-06-2003, 17:03    Subject: Quote
Lucas wrote:
For me, the ZKD exam is also coming up soon. That way, I know exactly what else I need to pay attention to...
Hi Lucas,
Are you also sure it's the ZKD? In our case, it was most likely the core plug closures... but changing them certainly didn't hurt icon_mad.gif.
____________
Kein Auto mehr!
Translated on 18-08-2026, 1:15.
Lucas
Post15-06-2003, 21:40    Subject: Quote
Hello!
There's a slight bubbling sound shortly after a cold start (audible inside the car), and the coolant level is slowly but steadily decreasing. I can't find any leaks. There's also nothing suspicious in the coolant or oil. It might not be that urgent, but I also have an oil leak at the camshaft seal and at the cylinder head cover... icon_sad.gif
Regarding biodiesel, you hear all sorts of things. I have at least had only positive experiences so far. However, I am a bit cautious when it comes to using it with the auxiliary heater in winter icon_wink.gif.
Greetings.
Lucas.
Translated on 18-08-2026, 1:16.
meyert
Post16-06-2003, 8:33    Subject: Engine Noises: ZKD & Bubbling Sounds Quote
Hello Lukas,
Don't bother me with this 'gradually disappearing coolant.' I didn't have any problems with it in city traffic or during leisurely highway driving, so I was even trying to get used to the gurgling sound. However, a more demanding drive on the highway caused the coolant consumption to increase dramatically. It's unfortunate when you end up stranded on the shoulder with an almost empty coolant reservoir and a flashing warning light icon_smile.gif.
By the way, changing the ZKD (presumably a specific component or setting) helped.
Thomas.
Translated on 18-08-2026, 1:18.
haehnlein
Post16-06-2003, 15:27    Subject: Quote
Lucas wrote:
There's a slight gurgling sound shortly after a cold start (audible inside the car), and the coolant level is slowly but steadily decreasing.
Hi Lucas,
Okay, that sounds like it will take about 4 days of working on it. icon_mad.gif One advantage is that you'll be able to easily access the core plug seals. icon_twisted.gif I would recommend that anyone with a high mileage vehicle replace those things (especially if the coolant has never been changed).
____________
Kein Auto mehr!
Translated on 18-08-2026, 1:20.
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Coolant leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front axle rumbling on Golf IV - Faults detected!! Transmission, Chassis, Body & Interior
No new posts Reprogram MFA: Oil Temp, Not Time, First Diesel Engine Technology
No new posts Fuel Injector Problems: Leak After Replacement Diesel Engine Technology
No new posts Coolant Leak Audi A6 2.5 TDI:( Diesel Engine Technology
