AGR Valve Calibration: How-To Guide
holzbein
Post18-09-2010, 18:34    Subject: AGR Valve Calibration: How-To Guide Quote
Hello fellow enthusiasts,
I replaced the AGR valve on a Skoda Fabia I, type 6Y. After a short time, the following error appeared:
"One error found:"
16786 - Exhaust gas recirculation system: Flow rate too high.
P0402 - 35-00 - -
"With this error, the EGR valve is (usually) not activated and remains fully open. I personally doubt this is the case with a new valve, and according to the AUTO-LOG, it is being activated."
According to Pieburg, an EGR valve should also be programmed. Does this make sense, and if so, how is it done with VAG-COM?
Thank you very much.
Translated on 24-09-2026, 16:36.
Post18-09-2010, 18:43    Subject: AGR Valve Calibration: How-To Guide Quote
Engine type? Gasoline or diesel?
Translated on 24-09-2026, 16:37.
chli1976
Post18-09-2010, 18:52    Subject: AGR Valve Calibration: How-To Guide Quote
Check if anything works with the default setting of 074.
VCDS
holzbein
Post19-09-2010, 10:09    Subject: AGR Valve Calibration: How-To Guide Quote
Engine code: BBY, 1.4 gasoline.
How does a basic calibration process generally work? Do I need to specify target values under certain conditions, or does the actuator adjust itself automatically after a certain amount of time?
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Valve N18: Replacement & Repair Diesel Engine Technology
No new posts N75 Valve: Function, Problems & Replacement Diesel Engine Technology
No new posts Regelgeschwindigtkeit des AGR Ventil Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Valve: How to Deactivate/Disable? Diesel Engine Technology
