VW Passat: Check ALG NW Control Unit (3B5)
klemmi 2
Post20-09-2010, 17:19    Subject: VW Passat: Check ALG NW Control Unit (3B5) Quote
Hi everyone, I have a question about my Passat 3B5 with a V6 engine (MKB ALG). It has absolutely no power. The mass airflow sensor is new, and the swirl flap control system works during the actuator diagnosis. I then manually locked it and drove it, but nothing changed. My question is: Can I use VCDS to check if the Nockwell sensors are working correctly, and whether the valve timings are correct (I once read somewhere that they are often not installed properly, but I can't find the article anymore). Hopefully, someone can provide some answers. Thanks, Jürgen.
P.S. I know this isn't a racing car engine, but it should really be able to go over 180 mph, right? It actually does pretty well up to that point.
Translated on 20-08-2026, 2:06.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check Passat 3BG mileage Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vacuum Pump Test: How to Check & Repair Diesel Engine Technology
No new posts Check VP37 Diesel Engine Technology
No new posts Check two-mass flywheel. Upload
