I spent the entire weekend browsing through this (and other) forums, but I've decided to post now.
I've been driving an A4 Avant TDI with the AFN engine for a few months. It has 122,000 kilometers (approximately 76,000 miles) and was manufactured in September 1996.
I am very satisfied with the engine, except for one small thing (it's my first diesel, and I'm not used to such low fuel consumption at all...
Under full load in 2nd gear, at approximately 2400 RPM, there's a slight dip in power – as I mentioned, it's just a small dip, but it's noticeable. After about 1600 RPM, when the boost kicks in, you can feel it. Then the power returns fully. It feels like a brief drop in boost pressure.
It's not noticeable when the engine revs up in neutral or in first gear, as it happens too quickly. In third gear or higher, you almost don't notice it (maybe a slight drop in third, but not in fourth or fifth), because it happens too slowly (and in my opinion, the boost pressure can recover quickly enough after the brief drop).
I can reach a top speed of just over 200 km/h, and the fuel consumption of just under 6 liters seems normal (with the air conditioning on). It's difficult to detect any rust.
Now, after reviewing all the articles and posts I found here, I've checked the VTG (presumably a valve or component). In my opinion, it seems okay. I can almost draw air through the tube with my mouth, up to the other end, or I can move the rod with my fingers (although the force of the return spring is quite strong - is that normal?).
Error memory is empty.
Do you need any more information? If it's the LMM (likely referring to a mass airflow sensor), I definitely won't replace it because it would cost too much for such a small problem. But if there's something I can do myself to fix it, I'd definitely like to try!
Sure, no problem. Here's the translation:
'Thank you in advance.'
mortl
