AJM Engine Oil: Which One is Best?
markus78
Post18-06-2003, 17:43    Subject: AJM Engine Oil: Which One is Best? Quote
Hi!
Inspection question clarified. A friend is taking care of it icon_wink.gif.
But: Which oil should I bring? It's for a Volkswagen Golf IV with the AJM engine, 115 hp TDI-PD.
Thank you all!
Markus.
Translated on 21-08-2026, 1:47.
Post18-06-2003, 17:46    Subject: AJM Engine Oil: Which One is Best? Quote
Hello Markus, please refer to the owner's manual for your vehicle.
Translated on 21-08-2026, 1:48.
markus78
Post18-06-2003, 19:36    Subject: AJM Engine Oil: Which One is Best? Quote
That's right. I saw it. However, I can't cite it right now because I am at work icon_cool.gif.
I can remember that it said 'VW-XXXXXX' on it. And I didn't necessarily want to buy the expensive VW oil, but rather ask if there was an identical oil from other brands. That's why I asked. icon_sad.gif
best regards, markus8O:roll:
Translated on 21-08-2026, 1:49.
Post18-06-2003, 19:41    Subject: AJM Engine Oil: Which One is Best? Quote
VW has various standards:
    VW Standards 50200 and 50500: "Conventional" gasoline and diesel engines.
    VW Standards 50300 and 50600: Vehicles with approved extended maintenance intervals (excluding, for example, vehicles with PD engines).
    VW Standard 50501: Pump-nozzle vehicle without extended maintenance interval.
    VW Standard 50301: Various gasoline turbo engines.
    VW Standard 50601: Pump-nozzle vehicles with approved extended maintenance intervals
Simply find the cheapest oil that meets your required oil specification.
For vehicles that do not have a Warm Water Installation (WIV), the oil used should also NOT be specifically designed for WIV systems.
Translated on 21-08-2026, 1:51.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Welches Öl?? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Which oil? Diesel Engine Technology
No new posts Which suspension? Transmission, Chassis, Body & Interior
No new posts BMM with DPF. Which engine oil? Diesel Engine Technology
